GL1500 oil from exhaust port - Steve Saunders Goldwing Forums
 3Likes
  • 1 Post By DriverRider
  • 2 Post By thaydon777
post #1 of 8 (permalink) Old 07-29-2016, 11:16 AM Thread Starter
Year: 1990
Model: GL1500
Hi, new to this forum and live in Australia and wanted to share an issue for some feedback. Just purchased a 1990 GL1500 with very low kms, 25,000. The bike has been stored for the last 15years and not run and I am currently going front to back checking everything, when replacing the timing belts the other day I was hand turning the crank and noticed some drops of engine oil dripping from the exhaust ports (headers currently removed for access to oil seals pipes etc). Pistons and valves all working as they should, bike has compression, I have not started it as yet, anyone offer advice on where that oil might be coming from , only dripping from the middle cylinder on both sides of the bike and only a few drops when hand turning the motor, seems to have stopped now. As far as I know oil was not put in the bores before the bike was layed up as the other four cylinders are dry. Thought it may have something to do with piston seals shrinking over time???
thaydon777 is offline
post #2 of 8 (permalink) Old 07-29-2016, 01:18 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Turning the engine over by hand is not going to pressurize or move any oil through the engine. Whatever came out was probably some leftover residue. Piston seals (rings?) do not shrink.
Keep forging ahead.
redwing52 likes this.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is online now
post #3 of 8 (permalink) Old 07-29-2016, 08:37 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Last owner may have fogged the cylinders before storage.
busdriver is offline
post #4 of 8 (permalink) Old 07-29-2016, 10:54 PM Thread Starter
Year: 1990
Model: GL1500
yes I did think about the previous owner who is now not with us and what he might have done to store the bike but the other four pots are dry, you would think that they are would have been the same, looks like I will just have to start it up and see what it does.
AZgl1800 and AZwngr like this.
post #5 of 8 (permalink) Old 07-30-2016, 06:32 PM
Oil pools and drips from the lowest point. Source may be higher up on the motor.
post #6 of 8 (permalink) Old 07-30-2016, 07:10 PM Thread Starter
Year: 1990
Model: GL1500
yes I was thinking about that but there is nothing obvious leakings, its stange that it was only coming out the exhaust port when hand turning the motor so it is being pushed out by the piston so can only assume its go something to do with bleeders or oil control rings.
post #7 of 8 (permalink) Old 07-30-2016, 07:37 PM
Or, it could even be old gasoline that got into open intake valves and gelled, then when the exhaust valve opens...
The stuff that was in my parts bike's fuel system could be easily mistaken for oil. It had that consistency and color.
post #8 of 8 (permalink) Old 07-31-2016, 03:08 AM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
I think Dennis could be right. The fact that it is only the middle cylinders could mean some old fuel (as the bike has been stood for years) is finding it's way out of the carb on the shortest route which is the middle arm of the inlet manifold, into the cylinder then out of the lower exhaust port.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
Auxillary/charging port GL1500 pwhalen Goldwing Technical Forum 1 06-26-2011 09:42 PM
Cleaning oil out of GL1100 exhaust? HomeBru Goldwing Technical Forum 9 06-02-2011 09:45 AM
85 1200 I oil port cleaning gotta love the wing Goldwing Technical Forum 4 04-16-2009 06:28 AM
Oil Drip From Exhaust Manifold numbers Goldwing Technical Forum 9 04-07-2007 09:47 AM
'93 GL1500 Interstate for sale in Port Orchard, nice! Jluvs2dive For Sale/Wanted Forum 16 07-24-2006 02:28 PM
