GL1500 no power to fuel pump - Page 2 - Steve Saunders Goldwing Forums
 2Likes
post #11 of 12 (permalink) Old 09-22-2016, 02:18 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Anything under 32 (108 kPa)inches will not hurt it. 18 (61 kPa) inches would be normal. I just suck on it with my mouth but some don't like to do that for some reason.
yep, this....
If you want to be more "diagnostic" about it, you could open one or both of the float-bowl drains to see how much fuel you pour out prior to trying to fill the bowls (my supposition is that you'll see little or no fuel drain from the bowls). A lower accuracy evaluation could be made by checking the output of the accelerator pump, since it also draws & primes from the bowls.
As an alternate method to fill the bowls, you can try like a half-cap of fuel into each carb-throat (hold the slider outta the way with the throttle twisted open), then try to start the bike -- a few of those 'cycles' should get the bike to pop-off a few times and allow the bike to pull vacuum on the petcock as the pump runs (great on the roadside when you don't wanna jumper the pump and suck on the petcock and all that...).
Best of luck!
redwing52 likes this.
satan is offline
post #12 of 12 (permalink) Old 10-18-2016, 09:35 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
-- @ thaydon777 -- Did'ja get your bike running?
satan is offline
no power to fuel pump rcmslm Goldwing Technical Forum 44 07-06-2016 03:18 PM
88 GL1500, No Power To The FUEL Pump. Ground Wire From Fuel Pump Burned. Willis Redd New Members Introduction Forum 5 07-06-2016 10:38 AM
84 Fuel Pump Issues - Lost Power to Pump banetranch Goldwing Technical Forum 37 09-05-2012 03:31 PM
Fuel pump not getting power Craig Goldwing Technical Forum 4 02-09-2009 11:12 AM
Help! Fuel pump not getting power GL1500 latweety61 Goldwing Technical Forum 4 10-04-2008 07:52 PM
