1500 Front Brake Micro Switch - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 09-20-2016, 11:04 AM Thread Starter
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
While riding today I noticed that my 'Cruise Set' wasn't working and when I got home I found that the brake lights were also lit all the time. I disconnected the rear brake switch first but the lights stayed on. When I disconnected the front brake lever wires the lights went out so I took off the micro switch block which I assume is faulty.
I've attached a picture which shows that one of the micro switches is shorter than the other. The one sticking out the farthest clicks nicely on and off but the short one does not. The short one pushes in on it's spring but does not click. Am I right in assuming this is the fault or is the micro switch supposed to act in this way?
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #2 of 13 (permalink) Old 09-20-2016, 11:15 AM
Sometimes you can clean those switches and be okay. I've used WD-40 or plastic-safe contact cleaner and they both worked about the same.
I'm sure new switches are still available but I can't even find them on the list.
http://www.westernhonda.com/fiche_se...99&fveh=132039
post #3 of 13 (permalink) Old 09-20-2016, 11:22 AM Thread Starter
John J's Avatar
Year: 2006
Model: GL1800A6
Thanks Dennis. I've sprayed it to within an inch of it's life but still no click on one of them. I think you've answered my question though in that both micro switches should click? Only one of mine is so I'll look for a new one.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Pan European ST1100
John J is offline
post #4 of 13 (permalink) Old 09-20-2016, 11:29 AM
It's on the master cylinder. http://www.westernhonda.com/fiche_section_detail.asp
post #5 of 13 (permalink) Old 09-20-2016, 11:52 AM
Maybe this will help.
redwing52 is offline
post #6 of 13 (permalink) Old 09-20-2016, 12:33 PM
Yup. That was the very first place I looked, and missed the switch completely. I'm amazed that I don't walk into walls.
post #7 of 13 (permalink) Old 09-20-2016, 12:38 PM
And John, I don't know if that switch is supposed to "click". It can probably be taken apart and cleaned, but with a list price of under $12, it's hardly worth the bother. Just go to your local dealer and get a new one.
post #8 of 13 (permalink) Old 09-20-2016, 12:46 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
I have just checked my old switch, the micro switches both click and they are at the same length as the long one in your picture.
It is a cheap part, 8.88$ in Partzilla, if you like to replace.
Erdeniz Umman is offline
post #9 of 13 (permalink) Old 09-20-2016, 01:11 PM Thread Starter
John J's Avatar
Year: 2006
Model: GL1800A6
Thank you for checking the click, confirms my thoughts that it was my problem. I've got one on order now. $35 over here but then again all parts are expensive here!
Thanks to everyone else too for the info which was really useful.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Pan European ST1100
John J is offline
post #10 of 13 (permalink) Old 09-20-2016, 01:22 PM
Wow! Three times list seems like more than continental markup.
GL1100 micro-switch for jack - safety switch haimayelet Goldwing Technical Forum 6 09-04-2012 05:13 PM
Front Brake Cruise Control cancel micro switch failed? Dusty Boots Goldwing Technical Forum 9 12-30-2011 10:13 PM
Front Brake Switch oharaLTD General Motorcycle Discussion Forum 2 03-26-2010 07:12 PM
Front GL1500 brake light micro switch removal Dusty Boots Goldwing Technical Forum 9 03-19-2010 04:30 PM
Need Front brake switch tomh124 For Sale/Wanted Forum 3 09-05-2008 10:37 AM
