86 GL1200 SEI voltage fluctuations - Page 3 - Steve Saunders Goldwing Forums
 10Likes
post #21 of 67 (permalink) Old 10-06-2016, 06:13 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
all gw's should disengage cruise when you pull the clutch or hit the brakes,could be one switch to not functioning correctly
neoracer is offline
post #22 of 67 (permalink) Old 10-06-2016, 08:44 AM
Bellboy40's Avatar
Year: 2000 & 1994
Yes, pulling in the clutch should disengage the cruise. I used to have an 85 LTD, which is basically the same, and that is how it worked. Check the micro-switch on the clutch lever. It might be defective or maybe the PO has done some funny things to the wiring.
Larry
-- Albert Einstein
Bellboy40 is online now
post #23 of 67 (permalink) Old 10-06-2016, 01:49 PM
Changing the fuse is not an update. It does add wiring and complication, if that's what you are trying for.
The dog-bone fuses are easy to check and very reliable. That's why Honda uses them.
post #24 of 67 (permalink) Old 10-06-2016, 09:44 PM
neoracer's Avatar
i would have to say that the dogbone itself is not the problem,but getting rid of them and the resultant wiring removes several normal trouble spots(ie solenoid conn)
and on the road doubt that any auto parts stores etc will have or even know what a dogbone fuse is,i worked in one for 11 years and saw them in a box and no one in the store knew we had them nor even knew what they were
neoracer is offline
post #25 of 67 (permalink) Old 10-07-2016, 11:00 AM
O'Reilly's still carries them today, I just saw some on the fuse rack.
Labeled "Honda" and in 30A and 50A at the time I looked.
post #26 of 67 (permalink) Old 10-09-2016, 03:24 PM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
So, I will be load testing the battery next. Here's what I've done so far:
Corrected the bad connectors by the regulator, made a short ground from the regulator 2 green wires to a cleaned area behind the regulator, ran a 10awg fused wire from the 2 red regulator wires to battery positive.
Results: 14.7vdc at idle...
But there's that intermittent flicker still. I've checked connections all over the bike... When it's cold, it doesn't flicker and the voltage is rock solid until it's ran @ 4Krpm for 20 or so seconds. Then the intermittent flicker starts...
Then later today after a short ride, I parked and turned off the bike then messed around with the compressor and front suspension (different issue...) then started the bike to find voltage output at or below 12vdc... ?... Battery load test is next.
EAGLECRY24 is offline
post #27 of 67 (permalink) Old 10-09-2016, 08:33 PM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
So, I just came across some interesting info... I tapped on the regulator/rectifier to find that the voltage flickered with every tap... Is this a coincidence or is the regulator failing?
post #28 of 67 (permalink) Old 10-09-2016, 08:39 PM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
So I decided to take the air filter out on this new to me SEI to find this...
post #29 of 67 (permalink) Old 10-09-2016, 09:47 PM
Can you say "running rich" ??
post #30 of 67 (permalink) Old 10-09-2016, 10:09 PM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
Yea. I've been wondering about a few things on this bike... Now I know. The PO apparently didn't maintain this bike... I've just ordered a new filter and am looking at a regulator rectifier.
That divot you see in the pic appears to be chewed by mice? Idk. I guess it let in enough air.
Fluctuations tfwarner23 Fun Forum 4 06-27-2013 08:43 AM
GL1200 SEi TPS voltage values puum Goldwing Technical Forum 1 07-20-2012 02:26 PM
Voltage fluctuations on GL1200...... trj827 Goldwing Technical Forum 14 05-31-2012 02:07 PM
1986 SEi GL1200 Voltage output cwolfie Goldwing Technical Forum 3 06-23-2010 12:10 PM
1986 SEi voltage issues shadogang Goldwing Technical Forum 15 06-07-2005 03:15 AM
