4 Way Flashers - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 10-09-2016, 02:41 PM Thread Starter
Year: 2004
Model: 1800 with 04/05 Hannigan Trike Kit with Whale Tail
Lightbulb 4 Way Flashers
2004 1800 Goldwing with 05 Hannigan Trike Kit. Four way flasher button will not stay depressed/engaged (button would not stay in the on position), tried cleaning it, that didn't work. Left Panel has been modified for the auxiliary gas tank with a two button toggle switch, one to turn on auxiliary gas tank pump on and other switch is not being used. I have been told by the repair shop that all I need is a toggle switch to replace the broken 4 way flasher button. I have taken the panel apart and the spare toggle switch is a three wire switch and the old 4 way flasher button switch has 4 wires coming off a little board which is the button mechanism and then has a two wire plug which I believe is for the light in the button. I know nothing about wiring and am looking to see if anyone could possibly help me get this toggle switch wired up or tell me what I need. New Left Panel is $250 bucks and then I would have to modify it for the auxiliary gas tank toggle switches.
glascutter is offline
post #2 of 5 (permalink) Old 10-09-2016, 03:29 PM
You have to have a 4 wire switch, double pole single throw for it to work.
BTW that switch panel is $220 retail and you can get it online for about $165.
post #3 of 5 (permalink) Old 10-09-2016, 07:06 PM
Year: 2008
Make sure the switch button is not binding on the panel. Did you disassemble to clean or spray down the shaft to get lube inside?
Charlie
flylow is offline
post #4 of 5 (permalink) Old 10-09-2016, 08:05 PM
harveysmedlap's Avatar
Model: 08 gl1800/sidecar
When the cruise control and four ways did that on my 04 I used WD 40 with the spray tube and compressed air to blow the dirt out from inside the switch. It took several tries and a liberal amount of WD and air, but they both work flawlessly now for less than five bucks. I know WD isn't the approved switch cleaner but I didn't have to worry about it melting the plastic switch or my paint.
harveysmedlap is offline
post #5 of 5 (permalink) Old 10-09-2016, 09:45 PM
CRC 2-22 is plastic safe and available at Home Depot.
It is also a pressurized aerosol.
4 Way Flashers??? Spider007 Goldwing Technical Forum 5 08-12-2011 07:42 PM
4 way flashers Ducky Goldwing Technical Forum 2 11-21-2008 04:39 PM
4 way flashers dentedsatelite Goldwing Technical Forum 3 06-17-2008 06:38 PM
Still need help with flashers utchuckster Goldwing Technical Forum 5 05-23-2008 09:06 PM
4 way flashers or emergency flashers Nightwing83 Goldwing Technical Forum 4 04-07-2007 10:05 PM
