94 1500 CB won't change channels - Steve Saunders Goldwing Forums
 2Likes
  • 2 Post By John J
post #1 of 9 (permalink) Old 10-18-2016, 06:54 PM Thread Starter
plain's Avatar
Year: '94'
Model: GL1500
Hey Guys...
A question about my 94 1500 CB. I had read several weeks back a thread that had a comment in it about when a CB gets stuck on a certain channel and won't change (either 39 like mine or 49) that there is a resistor? that needs to be replaced but I am having no luck finding the thread. The thread was started about another problem and this info was a gem in there.
Does anyone remember? Thanks!
plain
The nature of things....
'From High Expectations to Grim Determination'
I like order...and some day I will have it.
plain is offline
post #2 of 9 (permalink) Old 10-18-2016, 07:09 PM
dadztoy's Avatar
Year: 2009
Model: 2009 Silver GL1800 ABS
I don't remember anything about a resistor but have you tried cleaning the channel select switch real good with a good quality contact cleaner???
Mine would act up from time to time and that fixed it for me...
4 wheels moves the body
2 wheels moves the soul
GL1800 HPNAM9
Double Darkside - BT-45
dadztoy is offline
post #3 of 9 (permalink) Old 10-19-2016, 03:06 AM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
I didn't see the thread you refer to but have you tried disconnecting the bike battery to lose the CB memory? If it resets to channel 1 when the battery is reconnected and you can then change channels up to 39 and 40 again it will prove your switches are working. If you can't change from channel 1 then the switches may need cleaning.
In the past I have had other types of CB faults, eg. the numbers on the display not fully showing etc. and I found that using contact cleaner on the connection block behind the CB, the brown connection block under the left pocket and the main connection into the back of the radio itself fixed the problems.
gipsy42 and Aloha Tom like this.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #4 of 9 (permalink) Old 10-19-2016, 05:48 AM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
There is a common component failure in these . I do seem to recall one of the parts that failed was a resistor. I sent mine to Sierra Electronics for repair.
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #5 of 9 (permalink) Old 10-19-2016, 08:14 AM
Peter Goldwing's Avatar
Year: 2008
Model: GL 1800
Im with dadztoy here. Mine , after awhile of inactivity has problem changing chanels. I play with it for awhile and once it goes , it goes.
The problem with mine is that I dont use it almost at all.
Follow me on the spot
Peter Goldwing is offline
post #6 of 9 (permalink) Old 10-19-2016, 11:48 AM
Year: 94
Model: 1500 SE
per John, the BLUE can of CRC Electrical Contact spray cleaner - is safe for use around our plastics
Aloha Tom is offline
post #7 of 9 (permalink) Old 10-19-2016, 06:23 PM Thread Starter
plain's Avatar
Year: '94'
Model: GL1500
Okay Thanks Guys,
Will try the battery remedy this weekend. I am trying to get all my parts together by end of Dec. (Santy Claus ) to add a stereo amp, led brake lights etc., and generally go over my pahdnuh and make sure he is good for the next year so if resetting the CB by disconnecting the batt and cleaning all the terminals don't help I can try something else.
plain is offline
post #8 of 9 (permalink) Old 10-20-2016, 12:54 PM
Oh - THAT guy...
rpeters549's Avatar
Make: 1500
Even if the battery disconnect does the trick, you might consider cleaning the switch housings/switches when you have a couple hours to play. They can start to act up and you get used to it so don't think about it until suddenly it tips over the line to not working.
Avatar- 1963 Kenskill trailer
rpeters549 is offline
post #9 of 9 (permalink) Old 10-20-2016, 08:48 PM Thread Starter
plain's Avatar
Year: '94'
Model: GL1500
Absolutely. That is usually how things at my place go anyhow so I might as well do it right the first time. Hey, now there's an idea!
plain is offline
03 Won't start after filter change Bvanemon Goldwing Technical Forum 6 08-28-2016 09:57 AM
GL1100 won't start after oil change jh1990 Goldwing Technical Forum 9 03-10-2015 08:46 AM
When Stop Lights Won't Change Dannyboy1949 Miscellaneous Forum 19 01-14-2013 01:22 PM
ARGH! Won't start after timing belt change and new mufflers! smocksam Goldwing Technical Forum 34 04-04-2007 08:40 AM
CB Channels keener General Motorcycle Discussion Forum 3 05-10-2006 09:44 PM
