gl1200a - caught fire @ stator plug - Page 4 - Steve Saunders Goldwing Forums
 11Likes
post #31 of 41 (permalink) Old 11-24-2016, 09:50 PM
CrystalPistol's Avatar
I'm glad I ain't the only one who has nothing but loathing for these "tings".
Many a time on the side of the Interstate or other highway, sometimes in freezing or rainy or etc weather .... I have watched a poor truck's driver chase wiring faults through a long series of them. Like wise, a few people pulling trailers. I tried to be helpful ..... holding a flashlight or offering to call a service truck to meet us at the next exit. Abominations they are!
When we bought the Trike in 2004, soon afterwards I discovered that my buddy who was the original owner of it as a bike and who had converted it to a trike after going to Lehman's school had used what Lehman sent with the kit, these same connectors .... and he had for other light additions. Only took me a couple afternoons to remove and properly (IMHO) splice and or remake connections.
Them "tings" cut wire strands, let in moisture, and cause problems with dissimilar metals .... corrosion .... and they seem to let people down when times are the worst timing wise .... like when a trooper is loafing along behind at 1 am.
Bellboy40 likes this.
...(Candy Spectra Red )
CrystalPistol is offline
post #32 of 41 (permalink) Old 11-25-2016, 07:32 AM
Bellboy40's Avatar
Year: 2000 & 1994
Then suddenly those blue "tings" cause blue lights to flash!
Larry
-- Albert Einstein
Bellboy40 is offline
post #33 of 41 (permalink) Old 11-29-2016, 10:30 PM Thread Starter
Year: 86
Model: Aspencade
So I finally got some time to mess with my wing. Cut out all the burnt wire/connector mess.. it was not as bad as it looked - most of what appeared to be burnt was really just soot and wiped off. Final diagnosis - a previous owner had done a pretty poor job of replacing that original 3 wire plug. they used a 4 wire trailer light pigtail. first problem is that is pretty light gauge wire, maybe 18ga? second they used about a foot of it to make a 2 inch splice. third, they used crappy crimps. anyway, all the insulation burnt off all three wires for the whole foot long length hence all the fire. I should have given it a closer look before riding it so much. I saw it had been modded and took that as a good sign - but no.
After clean up, pulled out meter and tested the three wires from the stator, none were shorted to ground and .6 ohms between any pair.
turns out there was plenty of good slack left in those yellow wires/black stripe.. since I had so much/easy access I went ahead and soldered them and did a pretty good job for me, and shrink tube.
Had to charge battery.. apparently in all the fire excitement I didn't turn the ignition all the way off. After charging, fired up and @ ~3000 rpm showing 14.6 between battery posts. which I understand is a little high, but I'm not going to worry about that.
So no poor boy, looks like I'm back in business. Thanks for the advice and hand holding. I feel much better now!
ddlewis is offline
post #34 of 41 (permalink) Old 11-29-2016, 11:04 PM
the 14.6 will drop when the engine gets warm...
that is what the regulator is supposed to do with a cold battery, push it hard to ~14.6 to recharge it fast after the heavy drain from the starter motor.
then as the temp comes up to normal, the regulator will drop back to ~13.6
post #35 of 41 (permalink) Old 11-29-2016, 11:15 PM
I thought them wires looked a bit "puney" to be used there.
There is a mod that I need to do whether I do a Poor Boy or not ..... that is running a heavier wire from black wire coming out of the reg/rec past the plugs to the battery positive terminal through a relay activated by the ign switch. https://www.goldwingfacts.com/forums/...m-voltage.html
It is to give a more accurate "system voltage" reading to the reg/rec unit without the voltage loss at various plugs.
Mine is charging a bit high too, not bad, but "high" just the same. If it looses 0.3 or 0.4 vdc in connections, the reg/rec charges higher to get what it's looking for in that black wire. I already have my voltmeter wired through a ign switch controlled relay so I'll maybe use that. Everything coming off the battery positive terminal gets a fuse in my book.
AZgl1800 likes this.
post #36 of 41 (permalink) Old 11-30-2016, 12:45 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
there are some connectors out there that are good to use and seldom cause problems,they are called posi-locks and they have some for connecting wires together and posi-taps to tap into wiring circuits
POSI_LOCKS,TAPSOrder Online- Discounts
CrystalPistol likes this.
neoracer is offline
post #37 of 41 (permalink) Old 11-30-2016, 07:51 AM
I had forgotten about Posi-Lock connectors...
I am going to get some of those and keep them in my tool kit...
post #38 of 41 (permalink) Old 11-30-2016, 08:03 AM Thread Starter
Year: 86
Model: Aspencade
I like the posi-locks too. I have a little accessory 3 circuit fuse block on one of my bikes that has posi-lock terminals for the circuits.. pretty cool idea. The only negative is on the tap, if you tap into a very thin wire be careful that little spear tip can cut strands of wire in the source you're tapping into. happened to me and caused weird intermittent problems and took a long time to figure out.
ddlewis is offline
post #39 of 41 (permalink) Old 11-30-2016, 11:50 AM
CWN
CWN's Avatar
Year: Pro 1500
Model: 43 years winging it
June 1991 Road Rider stator survey.
CWN is offline
post #40 of 41 (permalink) Old 11-30-2016, 03:02 PM
Without the text, that makes no sense. The two graphics seem to disagree.
Chart one say's over 30% of Honda stators burn out but chart two says Honda gets more miles between burns outs than all but the BMW.
The only thing that makes the 'Wing's stator a real issue is its location. I remember '70s Suzuki 4 bangers having stator issues but it never became a big deal because it took an hour or less to replace it.
Bad Week for me - the F-150 caught fire and... AZgl1800 Miscellaneous Forum 6 09-27-2016 04:43 PM
GL1200A stator BluRidgeRider Goldwing Technical Forum 3 04-25-2013 04:48 PM
Brand new regulator smoked and nearly caught on fire poolguy Goldwing Technical Forum 7 10-25-2011 09:04 AM
GL1200 starter relay caught fire gpmillwright Goldwing Technical Forum 6 09-27-2010 12:21 PM
Annoying plug miss-fire.... slickster Goldwing Technical Forum 1 10-18-2007 08:15 PM
