84 Goldwing Fuel Guage - Steve Saunders Goldwing Forums
post #1 of 21 (permalink) Old 11-29-2016, 08:03 PM Thread Starter
big PIA
MysticFour's Avatar
Is it possible to add a simple fuel guage to my Aspencade using the sensor that is on tank? I need something to show how much gas is in tank until I can figure out the digital guage . I screwed it up by having wires reversed and did not realize it until after running several times. I changed fuel tank and reversed wires by mistake. the guage worked before I changed tank. I want to finish bike soon to get it ready to sell. I also need to find antennas for the bike as they are missing as well
MysticFour is offline
post #2 of 21 (permalink) Old 11-29-2016, 08:45 PM
cyclemax and Sierra Electronics stock the antennas
post #3 of 21 (permalink) Old 11-29-2016, 08:53 PM
Just the antenna(s) or the mounting bracket(s) as well?
Ken Bergen is offline
post #4 of 21 (permalink) Old 11-29-2016, 10:03 PM
Sure you could find just about any gauge and wire it in. A hot lead to 1 side and the other to the sending unit. May not be accurate but it would work.
post #5 of 21 (permalink) Old 11-30-2016, 04:21 PM Thread Starter
big PIA
MysticFour's Avatar
As far as antenna, I need brackets and all
post #6 of 21 (permalink) Old 11-30-2016, 05:11 PM
Large Member
wilmo's Avatar
on the antennaes, do you need the original? I use an electric hidden antenna under the seat. Powered by the accessory position and plugs into the regular antenna jack. Works great and is out of sight.
Wilmo
Rubber side down!
101421 miles as of 091418
wilmo is offline
post #7 of 21 (permalink) Old 11-30-2016, 05:22 PM Thread Starter
big PIA
MysticFour's Avatar
Does the same antenna operate cb and radio? If an electric is much cheaper I would be ok with that, hmm thinking about cb I don't remember seeing a mic on it, how does that work?
post #8 of 21 (permalink) Old 11-30-2016, 07:29 PM
OldNewbie's Avatar
Year: 2003
Make: GL1800
Model: Wing
is there a push-to-talk switch or lever on left handlebar controls? mic would be in helmet comms if stock setup??
OldNewbie is offline
post #9 of 21 (permalink) Old 11-30-2016, 08:21 PM Thread Starter
big PIA
MysticFour's Avatar
I just looked, the push to talk is a red button? kinda dark out there but it was a push button.
I have never used a cb on a bike before and I don't have any kind of helmet comms to even try it out, the same antenna works on radio and cb? still waiting to hear about that
post #10 of 21 (permalink) Old 11-30-2016, 08:28 PM
Honda used a shared radio/cb antenna.
7 volt regulator for fuel guage and temp guage Corney Goldwing Technical Forum 10 04-05-2015 10:17 AM
fuel guage siebo Goldwing Technical Forum 16 12-31-2008 10:29 AM
fuel guage drumman1225 Goldwing Technical Forum 6 04-06-2007 08:41 PM
78 GL1000 Fuel/Voltage/Fuel Guage Pod prizmatik Goldwing Technical Forum 2 01-09-2007 01:15 PM
fuel guage redlord Goldwing Technical Forum 2 11-29-2006 07:29 PM
