1996 gl1500 electrical issue - Steve Saunders Goldwing Forums
 2Likes
  • 1 Post By Bike...and Dennis
  • 1 Post By Erdeniz Umman
post #1 of 10 (permalink) Old 12-22-2016, 10:27 AM Thread Starter
Year: 1996
Model: GL1500 Aspencade
My wing shut down the other night after a long slow parade ride. It got hot but not overheated and was running fine when I shut it off. Went for a coffee and tried to start it about half an hour later. Turned the key and nothing,not even lights even though my LED's were working. Tried to boost it with a fully charged battery pack but again nothing. Checked all the fuses, put an ammeter on the new battery. Read 12.7 volts. So far I have taken the ignition switch connector apart and sprayed it with contact cleaner, checked the main fuse including the dog bone. Talked to a few guys but everyone seems to draw a blank. HELP!!!!!!!
Kenhale18 is offline
post #2 of 10 (permalink) Old 12-22-2016, 10:39 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Did you check the relays Number 3, 6 and related fuses on the left side and its connectors, probably melted and lost contacts due to overheat during the parade.
Erdeniz Umman is online now
post #3 of 10 (permalink) Old 12-22-2016, 11:18 AM Thread Starter
Year: 1996
I just removed the solenoid and had a hard time getting the connector off the top. It looks burnt. See pics. Perhaps this is the problem.
post #4 of 10 (permalink) Old 12-22-2016, 12:19 PM
NVSB4's Avatar
Model: 96 GL1500SE
That would be a sign that there is a problem.
Also, welcome to the forum.
There are lots of people ready, willing and able to help.
It's never too late to have a happy childhood.
Red=All bikes Blue=Wings
Chris
NVSB4 is offline
post #5 of 10 (permalink) Old 12-22-2016, 12:22 PM
It's certainly A problem, if not THE problem.
Anyway, welcome to the forum.
Could you please fill in your profile to include city, state and bike model & year? Thanks.
Erdeniz Umman likes this.
post #6 of 10 (permalink) Old 12-22-2016, 01:07 PM
Any loose contact will create resistance which will result in heat and voltage drop on the circuit.
post #7 of 10 (permalink) Old 12-22-2016, 02:43 PM Thread Starter
Year: 1996
Does anyone know about the bank angle sensor on a 96 wing? I looked at mine and it does not appear to be mounted to anything.
post #8 of 10 (permalink) Old 12-22-2016, 03:10 PM
If I understand your question correctly;
It should be mounted on the frame under the trunk, behind the right saddle bag. Its orientation is important to function properly.
If it is not mounted like that, I would think it was bypassed and does not have any function anymore.
redwing52 likes this.
post #9 of 10 (permalink) Old 12-23-2016, 12:44 PM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
If your bank angle sensor has been bypassed you will probably find the green connector under the seat looking like the one in the attached picture. The picture shows how to bypass the BAS.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #10 of 10 (permalink) Old 12-23-2016, 01:07 PM
Kenhale,
I have just noticed that the parts seem very clean and new. Have you replaced them and if so were they aftermarket or OEM parts?
Odd Electrical Issue...1996 SE wingpilot96 Goldwing Technical Forum 14 06-29-2014 09:57 AM
Electrical issue - GL1500 951Indy Goldwing Technical Forum 3 09-13-2010 04:30 PM
1996 GL1500 electrical issue Al K Goldwing Technical Forum 3 06-05-2009 12:28 AM
Gl1500 electrical issue PaWinger Goldwing Technical Forum 3 04-17-2009 09:46 PM
pdf file service manual (electrical) for 1996 gl1500 se ronnie 3945 Goldwing Technical Forum 14 06-12-2008 11:50 PM
