replacing sub & cruise filters - Steve Saunders Goldwing Forums
  • 1 Post By joe in calif
post #1 of 6 (permalink) Old 12-30-2016, 06:07 AM Thread Starter
Year: 1989
Model: 1989 GL1500 LE
I'm getting all the parts together to replace all the filters.
Do the SUB & CRUISE FILTERS have to be oiled ? And what oil to be used ?
jimod is offline
post #2 of 6 (permalink) Old 12-30-2016, 06:40 AM
No, put them in dry.
post #3 of 6 (permalink) Old 12-30-2016, 07:50 AM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
Some owners you will see in different threads on this forum do put oil on the sub filter but not on the cruise filter. Dave0430 is right though and the Haynes manual confirms that by not mentioning putting oil on the sub filter. Personally, I do put a very light coating of oil on it just to help catch any dirt but be careful not to overdo it and prevent air flow. The link below is a good picture guide to the job if you need to refer to it and the guy in the pictures does use oil.
http://goldwingdocs.com/forum/viewtopic.php?t=11036
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #4 of 6 (permalink) Old 12-30-2016, 08:33 AM
I don't think you're going to prevent air flow to the air jet solenoids. On both 1500s that I've had the sub air filter box off, the top and bottom halves of box don't seal and air is drawn in through the gap between the halves instead of through the filter material in the bottom, below the gap. I think this a crappy design. They would filter better if the medium was in the larger top half of the filter box instead of the bottom. Maybe not all 1500s leak air in between the halves but the two I've had experience with did.
spiralout is offline
post #5 of 6 (permalink) Old 12-30-2016, 08:53 AM
joe in calif's Avatar
when I did mine I put a light coating of oil on the sub filter
From another post a few years back
If you follow the service manual, sub air filter gets oiled but the cruise filter is supposed to be dry, no oil.
AZwngr likes this.
A NEW START ON 1/20/2017
joe in calif is online now
post #6 of 6 (permalink) Old 12-31-2016, 02:06 PM
Oh - THAT guy...
rpeters549's Avatar
Make: 1500
Dry is fine. If you choose to oil lightly do so and then squish it good in a paper towel or something to remove as much as possible. At least that's what I did and nothing ever blew up or failed over the course of almost 130k.
Avatar- 1963 Kenskill trailer
rpeters549 is offline
Cruise & Sub Air Filters RonHochhauser Goldwing Technical Forum 8 09-01-2014 08:41 PM
GL1500 Cruise and Sub Filters JoeS For Sale/Wanted Forum 1 07-13-2013 11:07 PM
GL1500 Cruise and Sub filters Wingmaster Shamus Goldwing Technical Forum 3 05-11-2012 06:16 PM
Cruise and Sub Filters 25ANV Goldwing Technical Forum 2 06-06-2010 10:56 AM
tips to replacing sub and cruise filters Psalmist Goldwing Technical Forum 2 03-11-2008 10:10 PM
