GL1500 thermostat change - Page 3 - Steve Saunders Goldwing Forums
 15Likes
post #21 of 48 (permalink) Old 04-25-2017, 08:35 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Originally Posted by Ekvh1 View Post
I was surprised at how quickly the fan came on without the thermostat in there.
I think, there is a misinterpretation here. Without a thermostat the coolant will circulate freely and continuously, which will delay the temperature increase.
Erdeniz Umman is offline
post #22 of 48 (permalink) Old 04-26-2017, 06:35 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
No misinterpretation, I was just commenting that it still comes on. I didn't say it came on sooner. At roughly 45 degrees out, I didn't expect it to come on for a long time. Like I also mentioned it's been too cold to ride it far since doing this. I could still have another issue. (Head gasket just done with copper, could be leaking)
Ekvh1 is offline
post #23 of 48 (permalink) Old 04-26-2017, 10:09 AM
Ok, it is more clear now.
post #24 of 48 (permalink) Old 05-04-2017, 09:10 PM Thread Starter
wing-man's Avatar
Model: It is a WING, man.
Then there is nothing wrong with your thermostat, you have a problem with the gauge.
The thermostat is currently stuck open. Coolant is constantly flowing, both cold and hot. I can see this movement while looking into the right radiator with the cap off.
Blocking the radiator front inlet and running the motor until the fans turn on is at the usual place on the gauge. When I first got this bike I took note where the fans turned on, on the gauge, that has not changed.
I do not lose coolant therefore no leaks.
HUMM-HUMmm-Hummm-hummmm-mmmmmmmmmm
WHAT A RIDE!
Quiet, powerful, comfortable and almost maintenance free.
wing-man is offline
post #25 of 48 (permalink) Old 05-05-2017, 03:50 AM
Year: 94
Model: 1500 SE
where on the gauge do the fans come on? about 3/4 or more like 9/10
Aloha Tom is offline
post #26 of 48 (permalink) Old 09-12-2017, 07:56 PM Thread Starter
wing-man's Avatar
Sorry it took so long to get back, I forgot about this thread.
Picture tells the story of my temperature needle.
Which is most desirable to change the thermostat?
Removing the radiators or carburetors?
There is room to maneuver with just the 2 fans removed. Question is, if there is a broken bolt can that issue still be accessed?
WHAT A RIDE!
wing-man is offline
post #27 of 48 (permalink) Old 09-12-2017, 08:08 PM
All three lines are well within the normal range. If that is as bad as it gets I would not worry.
redwing52 is offline
post #28 of 48 (permalink) Old 09-12-2017, 09:57 PM
Year: 94
Model: 1500 SE
I agree, my 1500 runs hotter than that indicated before the fans kick on,
still fairly high indication when they turn off too
Normal cruising temp anywhere in the main 2/3 is correct.
post #29 of 48 (permalink) Old 09-13-2017, 04:53 AM
It aint rocket science
DriverRider's Avatar
Model: The best
You should not be able to see the inside core of the radiator from up top, coolant needs to be filled to top of neck. Depending on your year of model coolant is always circulating in the right radiator. Thermostat opening temp is a little bit above the left hash mark.
With both fans out thermostat can be gotten to.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is online now
post #30 of 48 (permalink) Old 09-13-2017, 06:47 PM
If you are sure there is a difference from where it used to run keep in mind it might just be a change in the range of the meter itself. I see nothing to worry about right now.
GL1500 thermostat John Beganny Goldwing Technical Forum 4 02-28-2014 10:40 PM
Where is the GL1500 Thermostat? Dell77 Goldwing Technical Forum 2 04-06-2011 01:26 PM
88 GL1500 Thermostat DriverRider Goldwing Technical Forum 22 01-08-2011 01:00 PM
thermostat ? gl1500 h2smokin Goldwing Technical Forum 3 05-07-2010 03:18 PM
GL1500 thermostat TNroadrider Goldwing Technical Forum 1 02-12-2008 08:28 PM
