unusual occurrance - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 18 (permalink) Old 02-24-2017, 07:42 PM
All have given you good advice here. I'd pay attention.
post #12 of 18 (permalink) Old 02-24-2017, 08:35 PM
Year: 94
Model: 1500 SE
Fuel filters are a couple of dollars, I have several in my spares bag in case I meet a Winger in need on the road~
Let me just shove one thru the dvd drive for you
A qt of DOT4 brake fluid in synthetic is 5$
Find a free piece of wire like from a wire brush or guitar string end
Not having the wife freak out again...Priceless
Aloha Tom is offline
post #13 of 18 (permalink) Old 02-24-2017, 09:00 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Aliens on the mother ship? Seriously though, I might raise the bike up and check the wheel bearings, front and rear.
gumbyred
gumbyred is offline
post #14 of 18 (permalink) Old 02-24-2017, 09:02 PM Thread Starter
Sticks's Avatar
Year: 1995
Model: 1995 GL1500 SE
thanks everyone.
Forgive others. Not because they deserve forgiveness, but because you deserve peace.
If your not willing to forgive others, how can you expect God to forgive you.
Sticks is offline
post #15 of 18 (permalink) Old 02-26-2017, 10:33 AM
Location: Born in Pacific North West now logging in Tucson,AZ
Year: 1984
Make: Goldwing
Model: GL1200A
If it was me, Fuel Filter would be the next safety move.
Tucson Sand-Flea is offline
post #16 of 18 (permalink) Old 02-26-2017, 11:24 AM
life is good
siouxindian's Avatar
Make: gl 1500 interstate
Model: 91 interstate
Debris in the return hole of the master cylinder. Fairly common.
had that happen on a gl 1200.took a few times to finally figure it to be the brake master cylinder one on the handle bars.
life is good.
siouxindian is offline
post #17 of 18 (permalink) Old 02-27-2017, 01:16 AM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
Originally Posted by Sticks View Post
Redwing, it acted as if I was standing on the brake while traveling at 55. I have never experienced this with any vehicle.
Your fault was probably caused by the reasons stated earlier in this thread and hopefully you have it sorted now. Something similar did happen to a Honda Valkyrie many years ago while out on a long ride when we were hundreds of miles into the ride. The rear brake on this particular Valk suddenly and dramatically slowed the bike without the foot pedal being touched at all. We pulled up to investigate and the rear rotor was very hot. We came to the conclusion that the fault was being caused by the backing shim restricting the pads movement (you can see one clipped to the pad in the attached picture and they have a white sort of polystyrene layer between the pad and shim presumably for anti-squeal). We took out the shims and the fault never came back in over 40k miles. We used copper slip for the anti-squeal.
A second Valk had new oem rear pads and rota some years later with the shims installed and the brake was also binding. That owner also took his shims out and had no trouble from then on.
I realise these are different bikes and different pads but all information can be helpful when you are hunting a fault.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #18 of 18 (permalink) Old 02-27-2017, 01:17 PM Thread Starter
Sticks's Avatar
Year: 1995
I haven't found any problems yet, and it has not happened again. Thanks to everyone for all the ideas. If it happens again, or I run across the cause, I will let you know. Everything seems to be working as designed.
Sticks is offline
An unusual bike Fritz_The_Cat General Motorcycle Discussion Forum 14 09-05-2011 08:42 PM
Unusual 1500 adman General Motorcycle Discussion Forum 11 01-23-2011 11:27 AM
Unusual fysty-1 General Motorcycle Discussion Forum 1 08-20-2010 01:12 PM
An unusual bike.. lostinflorida General Motorcycle Discussion Forum 7 09-27-2009 06:44 AM
Unusual woodbutcher Miscellaneous Forum 9 06-25-2008 05:23 PM
