Wow! I've Never Seen an Axle Nut This Tight. - Steve Saunders Goldwing Forums
 9Likes
post #1 of 40 (permalink) Old 03-29-2017, 02:50 PM Thread Starter
Wow! I've never seen an axle nut this tight.
I soaked it overnight in PB and it still won't budge. Box wrench and 3 lb hammer won't even do it.
Any ideas before I get out the Dremmel?
CrystalPistol likes this.
post #2 of 40 (permalink) Old 03-29-2017, 02:57 PM
KD9SR's Avatar
Year: 2006
Model: GL1800 audio/comfort/nav
Heat. Someone may have used threaklock compound.
Sent from my SM-G930P using Tapatalk
KD9SR is offline
post #3 of 40 (permalink) Old 03-29-2017, 03:01 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
I would cut it out, because if it was over torqued once, I think it would not be safe to use that critical part anymore.
Erdeniz Umman is online now
post #4 of 40 (permalink) Old 03-29-2017, 03:04 PM
KD9SR's Avatar
Year: 2006
Threadlock.
KD9SR is offline
post #5 of 40 (permalink) Old 03-29-2017, 03:09 PM
Threadlock.
You can edit your post. See the edit button at the bottom?
post #6 of 40 (permalink) Old 03-29-2017, 03:10 PM
KD9SR's Avatar
Year: 2006
No, I don't. Using taptalk app on Android.
KD9SR is offline
post #7 of 40 (permalink) Old 03-29-2017, 03:14 PM
OK, I don't use that.
KD9SR likes this.
post #8 of 40 (permalink) Old 03-29-2017, 03:45 PM
Socket breaker bar and a pipe if necessary. Cutting is my last choice.
redwing52 is offline
post #9 of 40 (permalink) Old 03-29-2017, 03:51 PM
Magic Moderator
trike lady's Avatar
+1 on heating it.
Retired trike builder.
trike lady is offline
post #10 of 40 (permalink) Old 03-29-2017, 03:54 PM
azdesertdad's Avatar
Model: GL1100 Standard, GL1200-I, Kawasaki Vulcan 1600 Classic
Impact wrench? 36" 1/2" drive cheater bar?
And... did you remove the cotter pin from the castle nut?? Just wondering... ;-)
I may or may not have made that mistake, once, a long long time ago... hee hee...
Screw likes this.
A wing isn't an old mans bike, it's a wise mans bike. Often that wisdom comes with age. Sometimes not at all.
Four wheels move the body. Two wheels move the soul
Do something. Something is always better than nothing.
IBA #69314
azdesertdad is offline
GL1200, nut to tight jimmy r b Goldwing Technical Forum 14 07-19-2012 04:23 PM
Front Axle Nut Xtracho General Motorcycle Discussion Forum 4 05-20-2010 12:15 PM
Axle Nut '83 Interstate Colemadad Goldwing Technical Forum 5 04-24-2010 07:16 PM
rear axle nut luckey9 Goldwing Technical Forum 16 12-04-2007 03:34 AM
There is no cotter pin hole in my rear axle. Do you use Lock tight??? 83 Aspencade newbiker Goldwing Technical Forum 6 11-02-2007 07:07 PM
