What is this thing - Page 4 - Steve Saunders Goldwing Forums
 12Likes
post #31 of 42 (permalink) Old 04-02-2017, 04:49 PM Thread Starter
rocks's Avatar
Year: 1977
Model: GL1000
Like always, I really appreciate all your help. Yeah, that crack pipe is definitely going back in. It will take some time since I really need to polish my CB750F for the riding season. I am talking paint and shining it.
Thanks all again
OldSchool_IsCool likes this.
rocks is offline
post #32 of 42 (permalink) Old 04-02-2017, 06:12 PM
Originally Posted by rocks View Post
So now, I am going back to the engine, and put that thing back on.
Anyone knows a good (or oem) Honda Head Gaskets? I think I will need a couple.
You can split the case without removing the heads.
Ken Bergen is online now
post #33 of 42 (permalink) Old 04-02-2017, 06:15 PM
Not quite, you do have to remove the left head. If you haven't started it since having it apart just reuse the head gasket.
post #34 of 42 (permalink) Old 04-02-2017, 06:29 PM
I'm not seeing it.
The left pistons go in from the bottom of the cylinders not the top like on the right side.
post #35 of 42 (permalink) Old 04-02-2017, 09:23 PM
I'm not seeing it.
There is a main case bolt hidden under the head in the opening where the oil drains back into the case.
Ken Bergen likes this.
post #36 of 42 (permalink) Old 04-03-2017, 05:30 PM
Year: 2016 / 2000
Model: GL1800 / XR650L
I feel your pain. Been there, done that. Putting together my son's XL250R head, Boy got over zealous and dropped one of the alignment dowels down the timing chain hole. That wouldn't have been so bad if hadn't pushed it out of the way when trying to retrieve it. I had that engine apart four times before we got it back together. The good news; it was perfect when we were done and from there until we sold it started on the first kick, no matter how long it sat.
Good luck with yours. It does appear that you shouldn't have to take everything down to that part...still a pain though.
MaxThrust is offline
post #37 of 42 (permalink) Old 04-03-2017, 05:38 PM Thread Starter
rocks's Avatar
Year: 1977
Model: GL1000
I guess I just can't keep my hands off of it. I decided I split the halves again. And by the way, the left head has to come off.
So now, two questions.
What is the best way to clean all that sealant? I am really trying to avoid blades(sharp things scare me). Any good solvent?
I had some trouble with the neutral switch. The light stayed on even on gear. Any way to test it while I am there?
Planning to put the halves back first thing in the morning.
Thanks
flylow likes this.
rocks is offline
post #38 of 42 (permalink) Old 04-03-2017, 09:52 PM
Pull the switch out and spray in it with contact cleaner, IIRC there are some small holes in the side you can spray the cleaner in. Then test it for continuity with while pushing the spring loaded ball in & out. It should only have continuity when the ball is released.
post #39 of 42 (permalink) Old 04-04-2017, 06:59 AM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
I gota say, that's a pretty damn clean engine. Well done Rocks!
MaxThrust likes this.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #40 of 42 (permalink) Old 04-05-2017, 03:19 AM Thread Starter
rocks's Avatar
Year: 1977
Model: GL1000
Engine is assembled. It's was a pin in the neck to get the left side on. I only removed one head, so I had to angle it a little bit. But it in.
John J likes this.
rocks is offline
one more thing winginitrick General Motorcycle Discussion Forum 7 08-28-2010 02:14 AM
another bp thing UbarW Fun Forum 0 08-11-2010 01:41 AM
Look at this thing! marvo75 General Motorcycle Discussion Forum 27 07-14-2008 12:20 AM
You can't believe a thing I say !!! mls Goldwing Technical Forum 21 02-09-2008 06:30 PM
This is the best thing I've seen Hobie1 Miscellaneous Forum 12 10-22-2006 10:33 PM
