Cruise Control Adjustment 2016 GL1800 - Steve Saunders Goldwing Forums
  • 1 Post By joe in calif
post #1 of 8 (permalink) Old 04-13-2017, 08:41 PM Thread Starter
Year: 2016 / 2000
Model: GL1800 / XR650L
Question Cruise Control Adjustment 2016 GL1800
I've read a couple of threads about adjusting the cruise control lag. They all state that you can take the dash/speaker cover out and the trim around the ignition and see the adjusting collar. I could not find one, but I went under the front of the fairing and saw this on the port side. If you look at the center of the picture you see an adjusting collar. Is it possible they moved it somewhat for 2016? I have a non-airbag model. If they moved it here it should be reasonably easy to adjust.
MaxThrust is offline
post #2 of 8 (permalink) Old 04-13-2017, 08:46 PM
No, that is a throttle cable. I haven't done a post 2012 so I don't know how you get to it.
post #3 of 8 (permalink) Old 04-13-2017, 08:57 PM Thread Starter
Year: 2016 / 2000
Thank you, I'll keep looking.
post #4 of 8 (permalink) Old 04-13-2017, 09:17 PM Thread Starter
Year: 2016 / 2000
I think I found it. I had to dig much deeper, but there it is. Can anyone can confirm this? I probably will need to get my wife to hold it out with a screwdriver. It keeps popping back under the cover.
post #5 of 8 (permalink) Old 04-13-2017, 10:20 PM
dadztoy's Avatar
Year: 2009
Model: 2009 Silver GL1800 ABS
That's it... I also have not done anything past a 2009 so I don't know how the front end comes apart on the 2016, but on mine, I can pull the filler panel that is held in by a few quick disconnect buttons and that gives better access to the adjustment...
4 wheels moves the body
2 wheels moves the soul
GL1800 HPNAM9
Double Darkside - BT-45
dadztoy is online now
post #6 of 8 (permalink) Old 04-14-2017, 09:36 AM
joe in calif's Avatar
When you adjust it start the bike up and let it warm up to normal idle. Turn the nut until the idle increases then back it off until the bike returns to normal idle, Tighten everything up and it is adjusted perfect.
MaxThrust likes this.
A NEW START ON 1/20/2017
joe in calif is online now
post #7 of 8 (permalink) Old 04-14-2017, 10:15 AM Thread Starter
Year: 2016 / 2000
I haven't done that yet, but I will. Thank you for that advice. I gave it two full turns (marked with a sharpie) and then snugged it down. I took it for a test ride, but it was not really good enough to fully evaluate it. I will do that tonight or tomorrow morning.
Fridays are "Drive your Thumper to work day" so the XR gets some loving when I don't carry a lunch. I had just completed a full service on that one. New fork seals, new head bearings, flushed all brakes, new clutch lever, adjust clutch, valve lash, new plug, lube rear suspension, change oil, etc, etc.
post #8 of 8 (permalink) Old 04-14-2017, 09:57 PM Thread Starter
Year: 2016 / 2000
Hot Schtuff and I took a quick run to Wally World and the cruise seems to be spot-on now.
We are leading a run to Tombstone tomorrow and I'll have a better chance to try it out. I can then adjust further if needed.
I finally sprayed the sub-dash heater and trip controls, etc with silicone so I can get that piece apart easier. That is honestly the toughest part of disassembly for that section. With that connector lubed it goes pretty quickly.
GL1800 CRUISE CONTROL scootys Goldwing Technical Forum 15 06-02-2012 08:00 PM
GL1800 cruise control rods209er Goldwing Technical Forum 5 12-14-2010 06:41 PM
Cruise Control Adjustment toy4rick Goldwing Technical Forum 12 06-09-2008 11:31 AM
Cruise control GL1800 Geoffs GL1800 Goldwing Technical Forum 8 05-18-2008 09:16 AM
Cruise Control on GL1800 datadavid Goldwing Technical Forum 5 01-11-2008 11:10 PM
