GL1000 low compression after rebuild - Page 2 - Steve Saunders Goldwing Forums
 11Likes
post #11 of 12 (permalink) Old 04-22-2017, 09:11 AM
Model: 1976 LTD (X2) (two apart in VIN)..... 2008 Pearl White
Hey Rocks. If you need an excuse to take her for a ride let me know, I'm not that far from you......
Bill
rocks likes this.
77Pinto is offline
post #12 of 12 (permalink) Old 04-22-2017, 11:44 AM
Year: 94
Model: 1500 SE
By following him on the road you can tell if any exhaust smoke, its color and when happens- on the throttle or rolling off?
Lots of information from that.
Get that needed first few hundred miles on the ring set. Thousand of micro-hills and valleys have to level into each other,
and they are depending on you doing a new engine break-in ride(s)
That means no full throttle, no sustained throttle over 4000 and vary the rpm every 5-10 minutes on freeway cruise portion of the ride.
Use the gears to slow down like normal, helps the break-in process
If your owner or repair book says different - follow them.
Change the oil per book for new engine...500? 1000 miles?
All that metal rubbing together creates debris the oil filter hopefully captures.
Some like to go back and re-torque head bolts after 500 miles or so, several heat cycles.
If you have to adjust valves on 1000- ck them again.
Aloha Tom is offline
Low compression cromagjeff Goldwing Technical Forum 12 10-12-2014 05:28 PM
GL1100 low compression mad dog 60 Goldwing Technical Forum 18 07-01-2012 04:37 PM
Compression question and low 20mpg average, GL1000 WingForChrist Goldwing Technical Forum 26 03-09-2011 12:05 AM
Low Compression thessler Goldwing Technical Forum 17 12-05-2007 06:49 PM
Low compression, GL1100 LD Hack Goldwing Technical Forum 11 03-18-2006 08:12 PM
