"BACK UP " brake module-Which one? - Page 3 - Steve Saunders Goldwing Forums
 3Likes
post #21 of 24 (permalink) Old 05-09-2017, 08:16 PM
Year: 94
Model: 1500 SE
User configurable does not necessarily mean does what I want.
Sort of like lifetime guarantee...mine- yours- the companies?
Aloha Tom is offline
post #22 of 24 (permalink) Old 05-09-2017, 09:53 PM
Originally Posted by Aloha Tom View Post
Only going to hook it to the spoiler so no load issues. The rest of the bulbs are regular 1157-1156 on the 1500 tail.
Looked up some reviews and the trick setup is to solder in a momentary/bump switch on the 2 white wires.
To program you touch 2 wires together x number of times to do different program modes and can be finicky.
With the small thumb switch its like sending Morse Code.
That's exactly what I did and ran the switch up into the trunk for easy access.
If you're using it just for the spoiler lights, it needs to be tied in at the spoiler/brake light control module. The yellow wire there is the one to the spoiler lights.
Aloha Tom likes this.
spiralout is offline
post #23 of 24 (permalink) Old 05-23-2017, 07:31 AM
corkya's Avatar
Model: 1999 GL1500 Aspencade
Originally Posted by spiralout View Post
I have mine programmed for 4 strobe-like fast flashes, then 4 normal rate flashes then steady. Continuous mode is off and I'm using a 5 second time-out which means I have to let off the brakes for a full 5 seconds then reapply for the flashes to happen, otherwise it's a steady on when I reapply.
This sounds like a very visible setup. I am still struggling to get things configured right, but am getting some help from members here. Thanks for dumbing it down a notch so this old brain can pick it up.
corkya is offline
post #24 of 24 (permalink) Old 05-23-2017, 11:46 AM
PM sent.
GL1800 Fuel filler cap "blow back" "volcano" al.ott Goldwing Technical Forum 11 04-05-2012 02:10 PM
"WELCOME BACK TO THE FORUM "dennisthemenace" Redwing Miscellaneous Forum 2 11-10-2007 05:50 PM
What is the "Reserve Lighting Module" on my 76. Cajun66 Goldwing Technical Forum 2 05-31-2007 03:14 PM
Installing Signal Dynamics "BACK-OFF" Brake Light Module Boobarry Goldwing Technical Forum 2 07-06-2005 05:12 PM
