GL1200 Voltage regulator issue? - Steve Saunders Goldwing Forums
 2Likes
post #1 of 22 (permalink) Old 05-02-2017, 10:40 AM Thread Starter
Model: GL1500 Aspencade
I've got a 1985 GL1200 LTD that I picked up last summer. Seems to have a charging problem. Initially I assumed it was likely the stator. Ran the stator through the usual tests and it appears to be OK. I get ~5.5V coming out of each of the three yellow wires when the bike is running. BUT ... here's what I discovered last night. At the voltage regulator with the bike running but 3 yellows disconnected from the voltage regulator, I still get ~5.5V coming from each yellow from the stator. When I plug them into the voltage regulator, the voltage on two of the 3 remains at ~5.5V, but the third drops to <1V and the wire gets quite hot. Is this an indication of a problem with the voltage regulator and time for a new one?
Haven't tested the voltage regulator yet, partly because I don't know if I have the right meter to test it's function properly. Seems to me that there must be a short somewhere though.
doc2bmrd is offline
post #2 of 22 (permalink) Old 05-02-2017, 11:05 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
correct test with the reg connector disconnected is to check with an ac voltmeter,at approx 3K test wire a-b.a-c and b-c.readings should be in 40-70v range if stator is good, common on LTD's and SEI's is for problems also at the regulaor and the starter solenoid connector because of the higher charging current
donpauli likes this.
neoracer is offline
post #3 of 22 (permalink) Old 05-02-2017, 11:18 AM Thread Starter
I also tested it as you described and everything checked out correctly.
I did figure out how to check the voltage regulator ... and it failed. Had continuity between green and one of the yellows on the voltage regulator when I shouldn't (pos to green, neg to yellow ==> no continuity on two yellows, but continuity on other yellow)
Sooo ... looks like I need a new voltage regulator. Which brings me to my next question: Since it's an LTD, do I absolutely have to get a voltage regulator for an LTD, or can I put in one from an Aspencade?? (can certainly do a workaround with connector differences)
doc2bmrd is offline
post #4 of 22 (permalink) Old 05-02-2017, 12:01 PM
Model: 1993 GL 1500
I have a brand new Electro Sport esr570 in the box that I bought for my LTD last year, that I would sell. But you need to check all your connectors and wiring before you buy the Regulator. I thought I needed a regulator but it turned out to be bad connectors. Someone had did the splice job on the 3 yellow wires and hadn't done it very good. Also check the connectors at the regulator and wire them solid . If you want this Regulator you can have it for $80.00. Check it out on there Web site. One more thing, I think the 3 wires that go thru the loom probably need to be bigger, those wire's get really hot to the regulator and coming out of the regulator. The regulator get to hot to touch when the bike is running and there is not enough air flow around it under the false tank. I know there is a lot of people on here that won't agree with me on this but this is my thoughts. The LTD has a better stator that puts out more juice but the wiring is the same as the other bikes. I sold my LTD so I don't need the Regulator.
Jerry Burns is offline
post #5 of 22 (permalink) Old 05-02-2017, 02:03 PM
That test is absolutely useless. Even a bad stator can show DC voltage there.
post #6 of 22 (permalink) Old 05-02-2017, 03:42 PM
We should have a sticky for the correct way to test a stator...
post #7 of 22 (permalink) Old 05-02-2017, 04:48 PM Thread Starter
Which is why I said above that I DID test AC voltage between 3 yellow yellow wires and got correct voltage.
The stator is fine. The voltage regulator is not.
doc2bmrd is offline
post #8 of 22 (permalink) Old 05-02-2017, 05:01 PM
Before you condemn the regulator do the continuity check on the stator as no load AC voltage can be misleading.
Ken Bergen is online now
post #9 of 22 (permalink) Old 05-02-2017, 05:08 PM Thread Starter
I have also done that.
Again, the voltage regulator should NOT have continuity both directions between a yellow and green. It does. Bad voltage regulator.
Sooo ... now to find an LTD/SEi voltage regulator. Do I go used OEM (there's a couple on eBay) or one of the aftermarkets? Anybody got good/bad experiences with the ElectroSport ESR570 on an LTD or SEi?
doc2bmrd is offline
post #10 of 22 (permalink) Old 05-02-2017, 06:22 PM
I would say buy the one Jerry Burns offered.
Ken Bergen likes this.
Voltage Regulator, GL1200 seasicksid Goldwing Technical Forum 12 11-12-2013 12:40 AM
GL1200 voltage regulator dudeboy Goldwing Technical Forum 4 06-26-2013 09:02 PM
GL1200 voltage regulator oldfart66 Goldwing Technical Forum 8 09-13-2011 12:05 PM
GL1200 voltage regulator bakfix Goldwing Technical Forum 11 09-10-2010 04:46 PM
85 GL1200 LTD Voltage Regulator The Lemonator Goldwing Technical Forum 12 11-28-2007 08:22 AM
