Led Headlight bulb...wow - Page 2 - Steve Saunders Goldwing Forums
 6Likes
post #11 of 27 (permalink) Old 05-13-2017, 03:31 PM Thread Starter
big_sleezy's Avatar
Year: 1983
Model: GL1100 Aspencade
I understand how light is supposed to work with a hyperbola and the light at it's focus. With that being said, a halogen isn't at the focus of the light housing either. A halogen actually sits a little farther away from the focus like this led. The reason you do that is because if the lights were at the focus exactly you would have a beam of light rather than a scattering of light. You need scattered light to light up in multiple directions to give a good viewing angle. But you don't want it so scattered that there isn't much clarity downstream of the light. So a happy medium is what we are looking for.
Last night's results: first off no pictures, I'll get some tonight. I initially thought the bulb was shitty. But as it turns out my alignment was all off because I'm half retarded and didn't aim it right when I left last night. After I fixed the vertical alignment, the LED bulb put out very clear light. It should be noted that the light it put out was white, in contrast to the halogens "yellowish" color. The brights project very far, there is just a but of adjustment I need to fine tune to get the best results. I'll show you guys what I mean when it gets dark tonight. You'll probably see those pictures tomorrow.
Sent from my ZTE A2017U using Tapatalk
big_sleezy is offline
post #12 of 27 (permalink) Old 05-13-2017, 04:26 PM
briese's Avatar
I see that those little suckers have fans. I wonder if they will cause interference in the bikes audio systems.
1998 - GL1500 w/175,000 miles
2003 - GL1800 w/106,000 miles
briese is offline
post #13 of 27 (permalink) Old 05-13-2017, 04:27 PM
corkya's Avatar
Model: 1999 GL1500 Aspencade
That was my question too, how do they work with the stock reflectors? Also, do they generate more heat?
corkya is offline
post #14 of 27 (permalink) Old 05-13-2017, 04:51 PM Thread Starter
big_sleezy's Avatar
Year: 1983
I did notice a little bit of a hum in the audio when I turn the radio on, but that's with no volume. The hum doesn't get louder as I increased volume though. So you could say it isn't an issue. As far as heat, I don't think the LEDs themselves make heat, it's the power conversion that would make the heat because they have a built in ballast. That is what the hs/fan would be for. I rode about 30 miles and I didn't notice any light drop because of heat. You would expect light cutting out or dimming if the internal ballast got hot. More testing will be in order to figure that out. I'll hook up my extra bulb to a spare battery and report back with a heat figure.
post #15 of 27 (permalink) Old 05-13-2017, 05:35 PM Thread Starter
big_sleezy's Avatar
Year: 1983
The LED lights themselves get hot for sure, but the hs/fan stays at a tolerable temp after about 10 mins run time. Cool enough to touch.
post #16 of 27 (permalink) Old 05-14-2017, 09:52 AM Thread Starter
big_sleezy's Avatar
Year: 1983
In short, here is what it's looking like. Crapper picture quality I know.
I like them. I'm going to use them a while longer and see if they are actually better or if it's just me mentally fooling myself.
post #17 of 27 (permalink) Old 05-14-2017, 11:07 AM
What are we seeing? Why didn't you include a low beam shot?
post #18 of 27 (permalink) Old 05-14-2017, 11:10 AM Thread Starter
big_sleezy's Avatar
Year: 1983
The top is low beam I think. Look at the dash. The bottom high beam light is lit up. When the highs are turned on you get more light higher.
I definitely could still have alignment issues, because I took the pics last night on the way to grab some gas. Didn't make any adjustments. I'm sure I need to fiddle with them yet.
post #19 of 27 (permalink) Old 05-14-2017, 11:51 AM
corkya's Avatar
I'm probably legally blind (lol), but I don't see a real difference between the 2 pics.
Bike...and Dennis likes this.
corkya is offline
post #20 of 27 (permalink) Old 05-14-2017, 11:54 AM Thread Starter
big_sleezy's Avatar
Year: 1983
Lol look at the tree and the house. Thats where the bike was kind of pointed at. The picture is decieving because I took it down the road. But the bike was pointing more at the tree/house on the right.
Sorry for the crappy pictures guys, I'll try a road around here that doesn't have street lights
cyclops LED headlight bulb monkey_wrench Goldwing Technical Forum 21 11-21-2014 04:58 PM
80 Watt H4 LED Headlight Bulb (B10-105) ??? Metal_Bob General Motorcycle Discussion Forum 15 09-11-2014 12:57 PM
Gl1200 led bulb upgrade brandi02 Goldwing Technical Forum 1 08-02-2014 09:19 PM
LED bulb replacements fordtek Goldwing Technical Forum 5 06-02-2011 12:59 PM
LED Bulb for sale Munds Goldwing For Sale/Wanted Forum 5 03-18-2007 01:18 PM
