76 gl1000 wont turn over - Page 2 - Steve Saunders Goldwing Forums
 7Likes
post #11 of 16 (permalink) Old 05-14-2017, 07:03 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
It turns over with the kick starter?
Ekvh1 is offline
post #12 of 16 (permalink) Old 05-14-2017, 01:54 PM
Bellboy40's Avatar
Year: 2000 & 1994
Originally Posted by DBohrer View Post
Did you happen to read he is working on a 1976 Gold Wing....???????
Yes, I did. That diagram was for a 78 model and I just assumed (there's that word again!) the 76 would have the clutch switch also. I guess you are saying that was wrong.
Anyway I suppose it is a moot point since he said he has a ground on that wire.
Larry
-- Albert Einstein
Bellboy40 is offline
post #13 of 16 (permalink) Old 05-15-2017, 11:48 AM Thread Starter
yes.
owl76 is offline
post #14 of 16 (permalink) Old 05-15-2017, 12:42 PM
Originally Posted by Bellboy40 View Post
It seems your starter solenoid is not operating. Test for a ground on the green/red wire on the solenoid. It gets a ground from either the clutch pulled in or the neutral switch. Then look for 12 volts on the yellow/red wire while pushing the starter button. It you get ground on one side and battery on the other while pushing the start button then you have a bad solenoid. Here is a simplified wiring diagram for the starter.
So what doesn't apply?
Test for power on the green/red while pushing the button, it may show ground with a meter but it may not be good enough. If it shows power on the ground side when there is power on the + side there is a weak ground somewhere. Try a direct ground to the solenoid.
post #15 of 16 (permalink) Old 05-23-2017, 02:16 PM Thread Starter
turns out it was the solenoid, i put a new one in and it turns when the button is pressed now. thanks for all your help.
owl76 is offline
post #16 of 16 (permalink) Old 05-23-2017, 09:58 PM
Year: 94
Model: 1500 SE
awesome, thank YOU for reporting back- that really helps future users who find this problem in search,
and serves as thanks to those who offered their 2 cents
Happy Winging to you, and this forum likes pics of your bike--- parked in front of trip signs is always nice!
Aloha Tom is offline
GL1000 Wont Turn Over rrainey86 Goldwing Technical Forum 19 05-19-2014 09:47 PM
GL1000 Neutral light wont come on and engine wont start.... bdepew Goldwing Technical Forum 6 08-24-2011 09:59 AM
gl1200 wont turn over rac166er Goldwing Technical Forum 15 06-19-2008 07:18 PM
96 gl1500 wont turn off hydpumps Goldwing Technical Forum 12 05-18-2007 07:28 AM
wont turn over if hot Rich Howerton Goldwing Technical Forum 7 10-07-2006 08:49 AM
