83 Interstate Engine removal - Steve Saunders Goldwing Forums
 5Likes
post #1 of 22 (permalink) Old 05-15-2017, 09:50 PM Thread Starter
thefid's Avatar
Model: GL1100
Is there a good video that explains the steps of removing an engine from an 83 Interstate?
81 GL1100 Interstate (Runs)
81 GL1100 Standard (bad carbs)
83 GL1100 Interstate (seized engine - replacement has arrived)
thefid is offline
post #2 of 22 (permalink) Old 05-16-2017, 02:57 PM
Magic Moderator
trike lady's Avatar
How about a series on removal of the engine from Youtube?
It's for the 1200 hopefully it will help, also get yourself a Honda factory service manual and a Clymer manual.
Retired trike builder.
trike lady is offline
post #3 of 22 (permalink) Old 05-16-2017, 06:22 PM
https://www.youtube.com/watch?v=1lh29m7dcJ8
1200 and 1100 are close enough to the same, the 1 real difference is the circlip on the driveshaft the 1100 has where the 1200 doesn't.
If you have a Honda manual why would you want a clymer?
post #4 of 22 (permalink) Old 05-16-2017, 08:36 PM Thread Starter
thefid's Avatar
Model: GL1100
Thanks for your replies. I saw that video and needed to be certain before I jumped into the unknown...
thefid is offline
post #5 of 22 (permalink) Old 05-16-2017, 08:45 PM
Magic Moderator
trike lady's Avatar
Please get yourself a service manual also, it is very important and makes the job easier.
Then when you reassemble the bike you'll also have all the necessary torque specs for the fasteners.
Also have a dolly of some type under the engine.
post #6 of 22 (permalink) Old 05-16-2017, 09:52 PM
BrianInPA's Avatar
You never know... when you need to start a camp fire, and a clymer manual would come in very handy for that purpose.
Brian
BrianInPA is offline
post #7 of 22 (permalink) Old 05-19-2017, 11:05 PM Thread Starter
thefid's Avatar
Model: GL1100
I need help I'm STUCK!!!
Engine has been unbolted disconnected and sitting on the jack, however...
I can't move the Universal joint/drive shaft, it is stuck in place and does not move. The old engine is seized, could that be contributing to it? I couldn't move it before I unbolted it either. Not sure how to get it disconnected.
thefid is offline
post #8 of 22 (permalink) Old 05-20-2017, 05:25 AM
There is a snap ring holding the u-joint onto the output shaft (referenced in post #3).
spiralout likes this.
post #9 of 22 (permalink) Old 05-20-2017, 07:32 AM
roadwanderer2's Avatar
Year: 1983-traded for motorhome, 1986
Make: both honda's
Model: GL1100-traded for motorhome, GL1200 aspencade SEi
Send a message via Yahoo to roadwanderer2
Originally Posted by thefid View Post
I need help am STUCK!!!
Do you have the rear wheel and final drive off? If you do, take a pry bar, locate the inner end of the drive shaft knuckle thats hidden by the rubber boot at the rear engine cover and pry it back off of the output shaft of the engine. It should push back rather easily. thats how i got my drive shaft off of my 83 aspy. Should be the same as yours. You might have to raise the motor up a bit to get the output shaft level with the driveshaft to make it easier to push the driveshaft back.
Stuart.
roadwanderer2 is offline
post #10 of 22 (permalink) Old 05-20-2017, 09:48 AM
Stuart.
He's not trying to get the shaft out of the swing arm, he's trying to move the motor and it's output shaft forward out of the U joint. Dave's already given him the correct advice about that #%$&ing pain in the butt snap ring.
spiralout is offline
LTD engine removal Psalmist Goldwing Technical Forum 12 11-15-2010 11:22 AM
85 Interstate Engine Removal tgsguitar Goldwing Technical Forum 5 05-26-2010 07:37 AM
83 Interstate engine to 82 Interstate engine swap jobrien Goldwing Technical Forum 4 01-31-2010 10:51 PM
Engine swap 85 gl1200 asp getting interstate engine Question christoph Goldwing Technical Forum 7 08-24-2008 10:37 PM
Engine Removal '83 Interstate GL1100 tom Goldwing Technical Forum 1 08-05-2004 01:46 PM
