GL1500 surge issue. - Page 2 - Steve Saunders Goldwing Forums
 4Likes
post #11 of 36 (permalink) Old 05-19-2017, 07:13 AM
Bellboy40's Avatar
Year: 2000 & 1994
Originally Posted by gumbyred View Post
I have noticed if the idle is set too high you can get a surge in R.P,M.while riding also was what I was getting at. Especially if you are trying to compensate for plugged jets. I just used the idle speed of 750-775 R.P.M.s as proof that the carburetors are clean and pretty well balanced. Set it at what you need to keep battery charged.
Correct me if I`m wrong, but that knob seems to control only one carburetor. At around 775 I hit what I call the "sweet spot" for idle. (What was the cause of the surge gford?)
gumbyred
The idle knob turns a cable that is connected to the left carb but both carbs will move because of the shaft linkage between them.
Larry
-- Albert Einstein
Bellboy40 is offline
post #12 of 36 (permalink) Old 05-19-2017, 08:53 AM
corkya's Avatar
Model: 1999 GL1500 Aspencade
What did you so to solve it?
corkya is offline
post #13 of 36 (permalink) Old 05-19-2017, 09:09 AM
It's a link, click on the highlighted text.
post #14 of 36 (permalink) Old 05-19-2017, 09:12 AM
At what R.P.M. does the bike idle at? Any surge at idle? You should be able to turn the adjuster knob to the right, and just ahead of gas cap. I find that if bike idles at 750 R.P.M. to 775 by turning this knob, the carbs are pretty well synced. If it won`t idle at this speed, there may be carburetor jet blockage, so long as there is no vacuum leakage, new plugs and filters.
gumbyred
Synchronization and blocked jets are NOT related, neither is idle speed and a surge when riding.
post #15 of 36 (permalink) Old 05-19-2017, 08:50 PM Thread Starter
wing-man's Avatar
Year: 2000SE
Model: It is a WING, man.
He replaced a part.
GL1500, found under “Water Pipe”, #22, Sensor, coolant temp part #36151-MT8-003
I seen this thread a long time ago. I am searching for answers before asking.
HUMM-HUMmm-Hummm-hummmm-mmmmmmmmmm
WHAT A RIDE!
Quiet, powerful, comfortable and almost maintenance free.
wing-man is offline
post #16 of 36 (permalink) Old 05-19-2017, 09:02 PM Thread Starter
wing-man's Avatar
Year: 2000SE
Everyone seems to be stuck on idle surging, that is not the problem. It is at any speed and in any gear.
Neither of us have had the 90 degree pipe replaced under the carburetor. I have sprayed carburetor cleaner at that tube using the extended red tube for direct direction. The bike does not change RPMs and that tells me his is good.
IDLE?
His 900, mine 750. Both our bikes are charging around 12.8 to 13.2 with headlights on bright.
WHAT A RIDE!
wing-man is offline
post #17 of 36 (permalink) Old 05-20-2017, 12:42 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
IDLE?
I think that method will not work on this tube. Because we are talking about a collapsed tube, not a broken one.
The picture may help.
Also watch this video about a similar problem, which was found to be the orange tube was collapsing on high vacuum. And note that, that orange tube goes to ECU for ignition timing.
Erdeniz Umman is offline
post #18 of 36 (permalink) Old 05-20-2017, 04:36 AM
corkya's Avatar
Thanks. I didn't realize it was a link.
corkya is offline
post #19 of 36 (permalink) Old 05-20-2017, 08:05 AM
It aint rocket science
DriverRider's Avatar
Model: The best
Not really unless tested for correctly. That vacuum hose is under the rubber mat and there is no way the plastic straw can reach into that general area which must be accessed from the spark plug/wire region.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #20 of 36 (permalink) Old 05-24-2017, 01:25 PM Thread Starter
wing-man's Avatar
Year: 2000SE
We switched bikes and rode. I can tell you it is nothing like any one here is saying about surging. Although I didn't pull the clutch in at speed, maybe I should have.
What his bike feels like is (for say but happens in any speed) 2500 RPM in 5th gear and riding constant speed. His bike does not spark plug miss, they are all firing properly. There is a random momentary acceleration, it is as if a few couple extra cylinders were firing.
IF I may be so indignant to say it this way, you are riding along and you feel the momentary 'Jet Pulse' from your fart.
WHAT A RIDE!
wing-man is offline
GL1500 Surge Filters jp in mn Goldwing Technical Forum 3 11-16-2012 07:43 AM
Replaced my GL1500 surge filters AZwngr Goldwing Technical Forum 6 11-14-2012 10:36 PM
GL1500 terrible idle surge AQUAMAN Goldwing Technical Forum 29 04-30-2012 11:21 AM
starting issue low speed surge hyperspace Goldwing Technical Forum 7 02-18-2010 08:26 PM
RPM surge 1996 GL1500 jeffo Goldwing Technical Forum 6 12-14-2009 07:44 PM
