Poor Boy Conversion still available? - Page 3 - Steve Saunders Goldwing Forums
 8Likes
post #21 of 42 (permalink) Old 02-02-2019, 08:17 PM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
What is every one using for the crank pulley?
Are you using the key on the crank? If not how are you making sure the pulley is tight?
Wilcoy02 is offline
post #22 of 42 (permalink) Old 02-03-2019, 08:18 PM
Year: 1984
Model: Aspencade 1200
Because thats the power place ,where you drive the strap for the alternator .
dismantle yours,,SLOWLY and gently.you will need to take off the spark plug because of the engine compression that may twist the cam and their belt.
when you will unscreew the crank pulley BOLT,then you will see that there is a groove of about 3/16 deep for the hame made pulley too be fixed.you will need a longer bolt and a grade 8 minimum with some locktite,,,,no need too torque it like a fool.
be carefull,with the strap cam timing too
it can be done and gently.
gervais
ps english is not my language,i hoped i was,,readable
gervais is offline
post #23 of 42 (permalink) Old 02-16-2019, 12:07 PM
bigpoop's Avatar
Model: GL1200 Asp.Trike
Don is Alive and better than few yrs ago. he switched bikes to a low HD for his bad legs.
hes on Facebook ,,so a search and buy a poor boy kit from him. I have installed 2 ,waaaaaaay easier and faster than R&R of Stator.
bigpoop is offline
post #24 of 42 (permalink) Old 03-25-2019, 04:12 PM
MikeyDoubleDEE's Avatar
Year: 1987
Model: GL1200 Interstate
Hello Friends,
Looking into a recharging upgrade for my '87 GL1200 Interstate now that riding season is finally in sight for Central Wisconsin. I've been doing some research and it seems there are two viable routes to explore:
1. A Regulator/Rectifier upgrade like something from roadstercycle.com
or
2. This "poorboy" conversion of adding an automotive alternator to the timing belt area of the motor.
It seems like there are success stories for both. Every time I start my cycle (with only 25k miles on her) the starter seems like it barely has enough juice to turn the motor over...even after a long highway ride with high revs. Battery and stator were both replaced less than 10,000 miles ago. So I'm exploring a recharging system upgrade.
I guess I'm hoping for opinions and also access to this poorboy conversion. As the previous post mentioned, I did a facebook search but didn't find any pages or people that sell this "poorboy kit". Can someone point me in the right direction? Don't be afraid to consult, comment, add to, or persuade about the two directions I've been concluding.
Thanks!!
Wausau, WI
1987 GL1200 Interstate, 23000 miles, Purchased June 2018
MikeyDoubleDEE is offline
post #25 of 42 (permalink) Old 03-25-2019, 04:48 PM
You said absolutely nothing that makes me think you have a charging problem.
What you say might be a dirty or tired, or non OEM starter, or might simply be a bad battery. No symptoms of a charging problem.
So, my recommendation is that you take the bike to a reputable shop and have them diagnose the starter problem.
post #26 of 42 (permalink) Old 03-25-2019, 04:59 PM
Pure Texas's Avatar
Make: Goldwing
like Dennis said,25k just isn't enough miles to have charging issues but murhys law may prevail most every one uses AGM batteries and they are STRONG.Yours is the last year for the 1200 and i think it should have the best charging of them all,the early 1200 ha most of the problems,with the melting wires.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #27 of 42 (permalink) Old 03-25-2019, 05:01 PM
Pure Texas's Avatar
Make: Goldwing
Originally Posted by MikeyDoubleDEE View Post
Hello Friends,
or
Thanks!!
Did you mean to say,BATTERY AND STARTER AND NO STATOR?
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #28 of 42 (permalink) Old 03-26-2019, 01:41 PM
Year: 1987
Nope... The battery and Stator were indeed replaced by the previous owner.
Another reason to believe that I have poor recharging, is that when sitting at a stop light with my signal on, I can see the dash lights dimming on the same cadence as my flasher relay. As if the blinking signal light bulb has that much more drain on the electrical system. Thoughts?
Wausau, WI
post #29 of 42 (permalink) Old 03-26-2019, 03:17 PM
That pulsating is normal. If you want a bike you need to work on, go buy a Harley or something. It sounds like you have a treasure right now.
post #30 of 42 (permalink) Old 03-26-2019, 04:08 PM
glhonda's Avatar
Replaced parts do not necessarily mean "good" parts. Get a voltmeter and give us some battery voltage readings at idle and at 3000rpm. We can't see the electrons from here.
glhonda is offline
More help Poor Boy Conversion McFirefighter Goldwing Technical Forum 1 05-25-2016 08:26 PM
Poor Boy Conversion? Who's done it? dtherren General Motorcycle Discussion Forum 12 09-01-2013 02:34 PM
poor boy conversion b679995 Goldwing Technical Forum 4 04-02-2009 03:47 PM
poor boy conversion jbunn Goldwing Technical Forum 4 07-14-2008 05:56 PM
poor boy conversion in U.K. EDDIE W Goldwing Technical Forum 6 11-29-2007 01:25 PM
