Port and Polish 84 Gl 1200 heads - Page 3 - Steve Saunders Goldwing Forums
 12Likes
post #21 of 22 (permalink) Old 03-18-2019, 08:13 PM
Pure Texas's Avatar
Make: Goldwing
I built the exhaust on my 82 and until now didnít understand why it ran so well,it had full size headers and a GS 1100 muffler,it had a flat spot in the rpm range so I had some different size holes water jet cut and fitted it where the muffler bolted to the header pipes,found the right one to clean it up,I think it was 1 1/4 inch.Mine sounded a lot different than a stock motor.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is online now
post #22 of 22 (permalink) Old 03-18-2019, 11:18 PM
Originally Posted by trike lady View Post
I'd like to see a pic of this hot rod BMW you have. Many members here are proud of their builds and post their progress.
A little bit of knowledge can be dangerous. If you just get in there and start hogging things out odds are pretty good you will hurt performance. Matching the bottom of exhaust ports is never good as it increases reversion when the cam is on overlap. Bigger port sizes can hurt performance because it slows the speed of the air in the port. That causes fuel drop out and hurts low end torque. I bet Joe Average would have to be pretty lucky to improve over all performance with a grinder more than a couple of percent which would be negligible and not worth the effort. If you want to improve overall performance invest in a good 3 angle valve job and leave it at that. Most performance increase is right at the bottle neck where the valve and seat intersect.
limpy45 likes this.
redwing52 is online now
1200 heads Doug Diesel Goldwing Technical Forum 6 05-21-2012 05:24 PM
85 1200 I oil port cleaning gotta love the wing Goldwing Technical Forum 4 04-16-2009 06:28 AM
1200 Cylinder Heads TxWingNut For Sale/Wanted Forum 0 12-22-2008 12:44 AM
Polish ( english custon polish ) report mr_fibble_2000 General Motorcycle Discussion Forum 2 06-19-2007 09:23 AM
'84 and '85 1200 heads interchangable? lucky General Motorcycle Discussion Forum 3 01-31-2006 12:36 PM
