Gold Wing 1200 sei 1986 mod - Steve Saunders Goldwing Forums
 3Likes
post #1 of 11 (permalink) Old 06-03-2017, 03:06 PM Thread Starter
Hei, Hondaen fusker ved pådrag, da må jeg clutchen å ruse for å liksom renske opp systemet. Har skiftet luftmengdemåleren uten forandring. Noen som har forslag? Kan det vere dysene, pluggene, bensinpumpa eller eller. Takker for svar?PJAa
Per Joar Aabakken is offline
post #2 of 11 (permalink) Old 06-03-2017, 03:26 PM
Year: 2004
Make: Goldwing
Model: GL1800/GL1200/CB900C
PJ.What was the bike acting like before you changed the air filter,that didn't change your symptoms??
If you were getting bad or reduced fuel mileage?
Start with the easy stuff first.
Try a Fuel Injection cleaner.
I'm sure you can find some in Norway.
Here the popular cleaners are.
Techron. "Concentrate Plus" The best of the 4 formulas.
Seafoam is also widely used to clean fuel injectors.
Follow label instructions for the amount of gallons.
I tend to use double the strength the first time for better cleaning strength,then as directed as a regular part of keeping things clean.
Please explain more about what you need help trying fix??.
Rockstar is offline
post #3 of 11 (permalink) Old 06-03-2017, 03:29 PM
Magic Moderator
trike lady's Avatar
Hello and welcome to the forum.
Hei og velkommen til forumet.
I'm translating this via Google Translate:
Hi, Honda is cheating on my case, then I have to clutch to clean up my system. Has changed the airflow meter without change. Anyone who has suggestions? Could it be the nozzles, the plugs, the gas pump or or. Thanks for answering? PJAa
Retired trike builder.
trike lady is offline
post #4 of 11 (permalink) Old 06-03-2017, 04:16 PM
I still don't understand.
post #5 of 11 (permalink) Old 06-03-2017, 08:28 PM
Magic Moderator
trike lady's Avatar
Even translating the post it still doesn't make sense in English.
post #6 of 11 (permalink) Old 06-03-2017, 10:58 PM
Year: 1985
Model: Aspencade
Not being able to put something in context is a major problem with online translation. If you translate the three words after honda by themselves, you get cheating by appointment.
The bike is an SEI so it would have fuel injection. On cars there is a meter to measure the airflow so the computer can calculate the correct injector on time to give the correct air fuel ratio.
A possible reinterpretation is
My Honda is stalling when I open the throttle and I have to engage the clutch to keep the engine from dying. Changing the airflow meter did not fix the problem. Does anyone have any suggestions? Could it be the fuel injector nozzles, the spark plugs, the fuel pump or is there something else that could cause this? Thanks for any help you can give me.
Wes Scott is offline
post #7 of 11 (permalink) Old 06-03-2017, 11:02 PM
Seafoam....
spiralout is offline
post #8 of 11 (permalink) Old 06-03-2017, 11:20 PM
William_86's Avatar
Model: GL1500 Aspencade
i wonder why everyone recommends seafoam, i cant understand what he say and i doubt he may be able to get seafoam on the country he is from...
William_86 is offline
post #9 of 11 (permalink) Old 06-04-2017, 06:00 AM
It doesn't have an air flow meter so that doesn't translate either. Probably either the throttle position sensor or the PB (vacuum) sensors or their vacuum hoses.
post #10 of 11 (permalink) Old 06-04-2017, 08:39 AM
BrianInPA's Avatar
Because its easier than finding and fixing the actual problem.
DaveO430 likes this.
Brian
BrianInPA is offline
1986 Gold Wing dtherren For Sale/Wanted Forum 5 08-29-2010 11:10 AM
1986 Gold Wing 1200 Interstate bigswede General Motorcycle Discussion Forum 2 09-02-2009 03:23 PM
GL 1200 DX Gold Wing 1986 bwssr General Motorcycle Discussion Forum 9 08-01-2008 04:44 PM
1986 sei gold wing dannyh General Motorcycle Discussion Forum 8 05-23-2007 03:34 PM
1986 Honda : Gold Wing : Aspencade SEi dat7 Goldwing Technical Forum 10 04-04-2005 08:49 AM
