Saber Cycles GL1100 carb kit - what IS all this stuff?? - Page 2 - Steve Saunders Goldwing Forums
 4Likes
post #11 of 13 (permalink) Old 06-07-2017, 08:33 PM
BrianInPA's Avatar
Originally Posted by GearsGeek View Post
So the jets are no good and the o-rings probably don't fit. Why did I buy a kit again? ��
Probably because you had no idea what you were getting before you ordered it.
There should be a line in the Banner that reads: This forum does not recommend Sabre Cycles!
Brian
BrianInPA is offline
post #12 of 13 (permalink) Old 06-07-2017, 08:58 PM
So the jets are no good and the o-rings probably don't fit. Why did I buy a kit again? 😝
You live & learn. You can't change those o-rings without taking the plenum apart anyway, so why do they sell a kit without the plenum gasket?
post #13 of 13 (permalink) Old 06-08-2017, 07:44 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
I recently bought non oem jets from 4into1.com and they measured up pretty close to they're labeling. As mentioned before, you should check your current jets as lots of people think drilling them out is better. Then check Sabresuckle's jets.
1100' carbs are a chore.
Ekvh1 is online now
Saber cycle 82-209 Rebuild Kit for GL 1500 help jakes_home Goldwing Technical Forum 9 07-06-2013 01:55 PM
GL1100 carb kit jughead Goldwing Technical Forum 6 09-16-2009 12:22 PM
Where to buy carb kit/stuff? slickster General Motorcycle Discussion Forum 7 07-05-2009 09:22 AM
SABER CYCLES RB General Motorcycle Discussion Forum 53 06-14-2008 06:32 PM
GL1100 Carb Kit Question 82 Red Wing Goldwing Technical Forum 1 07-02-2006 03:18 PM
