Saber Cycles GL1100 carb kit - what IS all this stuff?? - Steve Saunders Goldwing Forums
 4Likes
post #1 of 13 (permalink) Old 06-07-2017, 03:15 PM Thread Starter
Year: 1983
Model: GL1100 Aspencade
Holy moly, look at all the O-rings! And this is just 1 of 4 packs! Where are all these lil' buggars supposed to go? Also, for anyone that was thinking of using this kit, I wouldn't recommend it. The jets look all kinds of wrong. ALL the hole diameters are different. See pics. Guess I'll just have to clean the old ones.
Seriously though, where do all the O-rings go? Mine's an '83 model, this kit was supposed to work. Are there extra bits for other models?
Pc 1 - new kit
Pic 2 - old stuff that came out
Pic 3 - drastically different main jet sizes
GearsGeek is offline
post #2 of 13 (permalink) Old 06-07-2017, 03:59 PM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
Previous owner may have drilled main jets out??? Check with micro drill bits.
Ekvh1 is offline
post #3 of 13 (permalink) Old 06-07-2017, 04:17 PM
We have a general rule around here. "NEVER BUY ANYTHING FROM SABER CYCLE".
That sums up my response, thank you.
post #4 of 13 (permalink) Old 06-07-2017, 04:22 PM Thread Starter
Year: 1983
Yeeeah, I realized that about 10 minutes after I had already placed the order. 😅
post #5 of 13 (permalink) Old 06-07-2017, 04:26 PM Thread Starter
Year: 1983
Also, I just found Randak's carb details page. Those o-rings fit on each end of the channels linking the carbs. Is it really necessary to split the plenum and pull all that apart, or can I get by with just blowing them out with cleaner and dipping the brass stuff?
post #6 of 13 (permalink) Old 06-07-2017, 04:31 PM
How many times do you want to do the job?
Ken Bergen is online now
post #7 of 13 (permalink) Old 06-07-2017, 04:48 PM Thread Starter
Year: 1983
Lol, carbs are scary, dude! I've never tackled one like this, so the less I have to take apart, the better. I don't have a new plenum gasket on hand if I buggar this one.
What diameter should the stock main jet hole be? That number on the side relate to a measurement?
post #8 of 13 (permalink) Old 06-07-2017, 05:21 PM
Maybe this will help. See attached. Yes the number is related. The bigger the number the bigger the hole. That is for the same length jet. Same application etc.
redwing52 is offline
post #9 of 13 (permalink) Old 06-07-2017, 06:47 PM
Do not use aftermarket jets, they are never the size indicated, the original ones are still good if you clean them. As as already mentioned don't buy from Sabre Cycle, you will be lucky if any of the o-rings fit anyway. I think the stock main jet is 145 which is 1.45mm , the low speed jets are 35 ( .35mm).
Ken Bergen likes this.
post #10 of 13 (permalink) Old 06-07-2017, 07:23 PM Thread Starter
Year: 1983
So the jets are no good and the o-rings probably don't fit. Why did I buy a kit again? 😝
Saber cycle 82-209 Rebuild Kit for GL 1500 help jakes_home Goldwing Technical Forum 9 07-06-2013 01:55 PM
GL1100 carb kit jughead Goldwing Technical Forum 6 09-16-2009 12:22 PM
Where to buy carb kit/stuff? slickster General Motorcycle Discussion Forum 7 07-05-2009 09:22 AM
SABER CYCLES RB General Motorcycle Discussion Forum 53 06-14-2008 06:32 PM
GL1100 Carb Kit Question 82 Red Wing Goldwing Technical Forum 1 07-02-2006 03:18 PM
