Finel Drive Noise - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 06-15-2017, 06:51 PM Thread Starter
McFirefighter's Avatar
Year: 1990
Model: Aspencade
Send a message via MSN to McFirefighter Send a message via Yahoo to McFirefighter Send a message via Skype™ to McFirefighter
Finel Drive Noise
Ok I need your thoughts I had a clunking noise coming from the ujoint area so I went completely through
the rear end, replaced the joint and checked everything with fine tooth comb. Cleaned every thing up and put new grease. All back together and still makes the same noise a clunking sound. It only does when I letr off the, it does not do it under power. Any Ideas and will it hurt to drive the bike. Please help
Patriot Guard Rider #144639
McFirefighter is offline
post #2 of 10 (permalink) Old 06-15-2017, 07:05 PM
A clunk in the rear wheel might transfer through the drive to the u-joint.
When you had the wheel off, did you look at the fit of the drive flange where the pins fit into the wheel?
Are you dead sure the wheel bearings aren't clunking?
Is it possible you have that much slop in the final drive?
post #3 of 10 (permalink) Old 06-15-2017, 07:23 PM Thread Starter
Year: 1990
Model: Aspencade
No everything was tight no slop that I could feel when I rotated the wheel on center stand. I know something is causing this noise but what.
post #4 of 10 (permalink) Old 06-15-2017, 07:37 PM
Is this something that started recently or something that has bugged you since you got the scooter?
Ken Bergen is offline
post #5 of 10 (permalink) Old 06-15-2017, 07:43 PM Thread Starter
Year: 1990
Model: Aspencade
Just started a while back.
post #6 of 10 (permalink) Old 06-15-2017, 07:47 PM
Did you change the type/brand of engine oil?
post #7 of 10 (permalink) Old 06-15-2017, 07:54 PM Thread Starter
Year: 1990
Model: Aspencade
The noise is coming from somewere in the drive line not motor. Like I said it does not make the noise under power.
post #8 of 10 (permalink) Old 06-15-2017, 08:08 PM
The drive line is connected to the motor.
post #9 of 10 (permalink) Old 06-15-2017, 08:36 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Not sure about the 1200, but the 1500 has 5 (I think) rubber cushions built into the rear wheel that act as shock absorbers. These will wear out in time allowing a "click".
gumbyred
gumbyred is offline
post #10 of 10 (permalink) Old 06-15-2017, 09:08 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Check your shock mount bushings and nuts are tight.
busdriver is offline
Final drive noise. Did I mess up. READ THIS IF YOU'RE GOING TO PULL YOUR DRIVE SHAFT! Quick Cal Goldwing Technical Forum 53 06-04-2015 10:31 PM
Final Drive Noise 00whiteSE Goldwing Technical Forum 18 05-13-2009 10:24 PM
Final Drive Noise DamonECii Goldwing Technical Forum 13 10-08-2007 09:26 PM
noise from final drive? Capriaz Goldwing Technical Forum 1 08-14-2007 04:58 AM
Final Drive Noise TJ859 Goldwing Technical Forum 4 04-22-2005 09:16 AM
