My wing is starting to have trouble starting up '84 Gl1200 I - Page 2 - Steve Saunders Goldwing Forums
post #11 of 16 (permalink) Old 06-19-2017, 10:14 PM
Originally Posted by MysticFour View Post
How old is the battery? Hope it's not 1 of Everstart from Walmart, those are junk, I know from experience
Been running a walmart battery for over 3 years.
post #12 of 16 (permalink) Old 06-20-2017, 03:59 AM
big PIA
MysticFour's Avatar
I have had a couple walmart batteries, did you get a am battery? Those I have not tried, the acid battery has poor warranty
MysticFour is online now
post #13 of 16 (permalink) Old 06-20-2017, 09:19 AM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
Check you battery cables too. Make sure they are tight AND clean at both the battery and at the other end. You mentioned that at one point you got no noise at all (assume you mean no cranking) then it would crank and sorta start. Loose or dirty batt cables could explain that.
+1 on the Neon coils. I put in a set and am quite impressed with the ease that my 1100 starts now. I had problems with restarts when hot, but that doesn't sound like your issue... yet.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #14 of 16 (permalink) Old 06-20-2017, 12:12 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
Did you have a thread on the previous problem?
I dont think i have Dennis, something similar though. ill consider the neon coil, thanks Dave. the battery is still under a year old, so not too old. I also changed the fuel filter under a year ago so i doubt its that. although i just forgot to mention an important detail. a couple of weeks ago i laid her down. she was down for only a good 20 seconds or so, but after that she wouldnt start. i spent 10 minutes or so until i decided to roll the throttle and she finally fired up. could it still be from this incident?
crimsonwing is offline
post #15 of 16 (permalink) Old 06-20-2017, 12:39 PM
(I have a Walmart Everstart battery in all three of my Goldwings, all at least three years old or more.)
When you laid the bike down you could have sloshed some junk loose that is now plugging a carb jet or some such. Does it run okay once you get it started?
bruce p is offline
post #16 of 16 (permalink) Old 06-29-2017, 02:50 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
runs just fine once started. but iith as been a while now since the issue has occurred. so maybe it was just some some junk clogged up.
New GL1200 Wing owner and a starting problem PatrickW Goldwing Technical Forum 17 10-26-2013 01:55 PM
GL1200 not starting after wing gets bath winger4life68 Goldwing Technical Forum 9 06-16-2012 08:36 PM
Not your average starting trouble busmoss Goldwing Technical Forum 11 12-11-2008 12:01 PM
GL1200 - Trouble Starting Hot jackofroses Goldwing Technical Forum 11 10-20-2007 01:04 AM
starting trouble dkfsr Goldwing Technical Forum 7 07-01-2006 10:21 PM
