1984 GL 1200 died - Page 5 - Steve Saunders Goldwing Forums
 10Likes
post #41 of 53 (permalink) Old 07-08-2017, 11:00 PM
Would it be reasonable to say that you could put pulse generators on the front like they are on the rest of the years. Are the mounts already there could they just be drilled and tapped?
The front of the 1984 engine block is like the 1000/1100 so without a lot of fabrication it's not possible.
Ken Bergen is offline
post #42 of 53 (permalink) Old 07-08-2017, 11:41 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
If that's the case it's probably not worth even trying because the amount of fabrication would be very significant considering the minoot adjustments necessary to get the timing right thanks for the feedback Ken.
A guy down the road has an 84 he's recently come into possession of and the former owner was telling him that he believed that the pulse generators were bad. The former owner even bought the pulse generators but did not install them at this point the bike does not run for whatever reason.
I figure I'll be helping him fix the bike at some point so I was just kind of trying to find out what options there were for that pulse generator guess the engine needs to come out.
Let us know how you make out once you get that pin replaced and things back together.
JeffMayfield is offline
post #43 of 53 (permalink) Old 07-10-2017, 08:16 PM Thread Starter
Year: 1984
Model: GL-1200 Aspencade
Well Folks... It lives! Put the engine back in the bike, cranked her, and pow fired right up. Next issue... I put in a new stator last year... has 2 hours on it, but when I check the voltage across the battery is only going up to 13.5 volts at best. Doesn't seem like the light brightens much at all. Took it for a spin with the battery I had, and it died... so, I bought a new battery hoping it was a bad cell that would not allow it to charge to 14-15v at 3000... same. Anyone???????????????????????????????????????????? ??????????????????????????????????????????????
post #44 of 53 (permalink) Old 07-10-2017, 08:21 PM
13.5 volts should be fine unless the battery charge is low. Even then, that is charging and much more will burn up batteries.
post #45 of 53 (permalink) Old 07-10-2017, 08:40 PM Thread Starter
Year: 1984
Okay... Will give her a go and see what I got. Will run it for a bit then check voltage again and see?
Thanks again everyone for all your help!
... Off to Roar On The Shore in Erie, Pa this week...
post #46 of 53 (permalink) Old 07-10-2017, 09:10 PM Thread Starter
Year: 1984
One Last thing... for now LOL... When I pull in the clutch she will backfire occasionally... Air leak, jetting issue???? Thanks
post #47 of 53 (permalink) Old 07-10-2017, 09:11 PM Thread Starter
Year: 1984
I have to get to the top of this mountain!
post #48 of 53 (permalink) Old 07-14-2017, 01:58 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
slow air cutoff valve located on the carburetors could be at fault when was the last time the carburetors were rebuilt?
post #49 of 53 (permalink) Old 07-14-2017, 02:46 PM Thread Starter
Year: 1984
I bought the bike with 52000 miles... it now has 78000... I don't know if the carbs were ever rebuilt? Maybe, my next adventure...
post #50 of 53 (permalink) Old 07-14-2017, 08:34 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
You could try putting some miles on it using seafoam or Marvel Mystery Oil or tcw3 otherwise known as two cycle oil. By running in the gas you may clear up some of the issue.
At some point the carburetors probably will need addressed such as syncing and possibly rebuilding them.
But for now if everything else is in working order it may be time to ride the bike a bit before you decide what's wrong.
GL 1200 Ran rough then died goarmyonem Goldwing Technical Forum 16 01-17-2014 01:11 PM
Help 1200 died justwingnit Goldwing Technical Forum 12 05-11-2013 09:48 AM
First ride on the 86 1200...and it died billy_bob169 Goldwing Technical Forum 17 04-06-2011 08:50 AM
bike just died part 2 (84 aspen. 1200) justwannaride Goldwing Technical Forum 3 04-28-2010 06:04 PM
Headlamp died on '86 1200 bmjudd Goldwing Technical Forum 5 07-17-2007 03:50 PM
