Valve tick problems 83 gl1100 - Steve Saunders Goldwing Forums
 2Likes
post #1 of 13 (permalink) Old 06-21-2017, 12:37 AM Thread Starter
I have a 83 gl1100 with what I thought was a serious valve tick on either cylinder 2 or 4. I've checked lashing and adjusted several times with no positive results. I've removed head and inspected valves, cam, and rocker arm assembly and didn't see anything out of the ordinary. Timing belt was replaced 3000 miles ago. Anything I could be missing? It's a pretty loud tick coming from left side of bike.
Dustin Lee Coit is offline
post #2 of 13 (permalink) Old 06-21-2017, 06:07 AM
If the head is still off turn the engine to T1 and see if the #2 piston is all the way to the top of the cylinder then turn it to T2 and check #4, compare the 2. Also look at the exhaust ports for signs of a leak.
post #3 of 13 (permalink) Old 06-21-2017, 07:08 AM
RB
RB's Avatar
Send a message via AIM to RB
Check you headers and exhaust for a small leak that can sound like a valve tick. Use a dowel to pin point the sound
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #4 of 13 (permalink) Old 06-21-2017, 10:29 AM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
I was having the same problem. My timing belts would move 1/2 tooth causing the ticking sound.
I found the center cam wheel had worn the keyway down causing the belt/pulley to slip. I could move the pulley 1/8 inch by hand. They should not move at all. This allowed the one piston to just touch the top and thus a clicking sound.
This probably is not your problem but it was mine.
Wilcoy02 is offline
post #5 of 13 (permalink) Old 06-21-2017, 11:31 AM
Come to think of it I had one with the same problem, loose cam pulley bolt. No way it lets a valve touch a piston though. Takes at least 3 teeth off to do that.
Bike...and Dennis likes this.
post #6 of 13 (permalink) Old 06-21-2017, 01:15 PM
BrianInPA's Avatar
Miss aligning a belt 1 tooth will create a tick. That darn false index mark on the right side cam pully bit me and the only reason I knew it was because of the ticking sound from the right side head.
Brian
BrianInPA is offline
post #7 of 13 (permalink) Old 06-21-2017, 05:27 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Seems like the problem found out years ago was rocker arms moving sideways a bit. Someone came out with needle bearings for the rocker arms that supposedly eliminated the sound. No longer available.
gumbyred
gumbyred is offline
post #8 of 13 (permalink) Old 06-21-2017, 07:07 PM
There was an issue with the 1200s that required centering the rocker arms. Maybe it applies to the 11s as well.
theRide likes this.
post #9 of 13 (permalink) Old 06-21-2017, 11:42 PM
If the engine has worn out valve guides it can sound just like lifter noise. If there has been no repair in that area it would be very common to have both worn guides as well as worn valve stems. Much more common on the exhaust valve. Good place to break out that inexpensive and handy mechanics stethoscope.
redwing52 is online now
post #10 of 13 (permalink) Old 06-22-2017, 06:36 PM
Old Fogey's Avatar
Model: as in the signature, but subject to change!
Perhaps you might find an answer with these tips:
http://www.wingovations.com/rocker-s...fix/4579471094
http://www.wingovations.com/cams-and-rockers/4579471096
wingformation on
1976 GL1000 \'The Swan\' - from an ugly ducking..
1979 GL1000 \'Black Bess\'- original.
Old Fogey is offline
GL1500 reed valve tick knklehd1 Goldwing Technical Forum 6 04-14-2014 08:16 AM
gl1500 tick tick tick knklehd1 Goldwing Technical Forum 10 01-16-2013 01:08 PM
83 GL1100 Engine Tick BeanMan33 Goldwing Technical Forum 14 05-02-2009 09:15 PM
Will a fuel pump tick GL1100? DarinS Goldwing Technical Forum 5 05-19-2007 09:23 PM
stereo TICK TICK TICK Devil_Dog Goldwing Technical Forum 2 04-18-2007 05:19 PM
