GL1500 turn signals won't cancel - Page 4 - Steve Saunders Goldwing Forums
 10Likes
post #31 of 60 (permalink) Old 06-28-2017, 05:05 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Originally Posted by MysticFour View Post
Sorry, I don't understand any of that, How hard would it be to put mine the correct way? I want the auto cancel feature working
It shouldn't be difficult for a normal bike, but on yours it is obvious that somethings happened and you should restore them during replacement or repair.
If you can't find the parts or find them expensive it is just an alternative to keep in mind.
Erdeniz Umman is offline
post #32 of 60 (permalink) Old 06-28-2017, 05:20 PM
And also, I am not sure you have mentioned but, if your bike is an Interstate model you will not have an Turn Signal Auto Cancel Unit.
redwing52 likes this.
post #33 of 60 (permalink) Old 06-28-2017, 05:23 PM Thread Starter
big PIA
MysticFour's Avatar
Aspencade
MysticFour is offline
post #34 of 60 (permalink) Old 06-28-2017, 05:28 PM Thread Starter
big PIA
MysticFour's Avatar
Didn't realize I did not have that listed but I just fixed that
post #35 of 60 (permalink) Old 06-28-2017, 05:41 PM
Here is the parts needed to put it back as far as the cancel unit is concerned. Not sure what other modifications are done upstream though. This one ships from Canada. It will give you a picture of the switch and brackets for the steering angle sensor. If you ask someone in the US I bet they would set you up with the brackets also. Might look at the plug by the top of the steering stem to see if it is there and in one piece. If you are not real experienced you might have to work through this with the guys. They are sharp and will get you going but be patient. Might be wore than a one step process.
http://www.ebay.com/itm/HONDA-GOLDWI...pYPDYP&vxp=mtr
DBohrer likes this.
redwing52 is online now
post #36 of 60 (permalink) Old 06-28-2017, 06:26 PM
Originally Posted by Erdeniz Umman View Post
Here is what I have prepared as an alternative solution for the turn signal cancel unit using two relays.
There may be something like this on your bike as well.
Pretty ingenious. Doubtful he has anything like that because his won't cancel at all. Someone probably just made a permanent ground to the flasher.
Erdeniz Umman likes this.
post #37 of 60 (permalink) Old 06-28-2017, 06:27 PM Thread Starter
big PIA
MysticFour's Avatar
how hard is it to get to the upper part of that? do I need to pull the false tank off or anything?
post #38 of 60 (permalink) Old 06-28-2017, 06:37 PM Thread Starter
big PIA
MysticFour's Avatar
I am hoping to make a weekend trip down to Arkansas within next month or so on the bike
post #39 of 60 (permalink) Old 06-28-2017, 06:53 PM
Read through the pictures from #14 to #24 in this link to reach and remove the unit.
http://goldwingdocs.com/forum/viewtopic.php?t=12367
post #40 of 60 (permalink) Old 06-28-2017, 07:12 PM Thread Starter
big PIA
MysticFour's Avatar
there is problem with that, there is nothing to remove on mine at moment, but at least I know to put 1 in is reverse of that. I may run out and take look and see what they did to the wiring or try to anyhow
, I just went and took top covers and this is what I found.
GL1500 turn signals cancel before making a turn ob1jeeper Goldwing Technical Forum 40 08-06-2014 10:10 AM
94 Interstate auto cancel turn signals mtfamily Goldwing Technical Forum 4 08-17-2011 06:44 PM
GL1100 self cancel turn signals box Goldwing Technical Forum 3 04-16-2011 09:37 PM
Manually cancel GL1500 turn signals BHAZLET Goldwing Technical Forum 16 03-13-2011 06:18 PM
GL1800 turn signals auto-cancel gwjr Goldwing Technical Forum 4 04-30-2010 07:50 AM
