GL1500 turn signals won't cancel - Page 5 - Steve Saunders Goldwing Forums
 10Likes
post #41 of 60 (permalink) Old 06-28-2017, 07:15 PM Thread Starter
big PIA
MysticFour's Avatar
So it looks like all I should have to do is get a new unit and disconnect that ground wire I hope. Hope I can find a unit at a decent price
MysticFour is offline
post #42 of 60 (permalink) Old 06-28-2017, 07:54 PM
eBay is reasonable. Lots of them available.
redwing52 is offline
post #43 of 60 (permalink) Old 06-28-2017, 09:48 PM
Looks like all you need to do is put a cancel unit in it and plug it in.
post #44 of 60 (permalink) Old 06-29-2017, 02:37 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Originally Posted by MysticFour View Post
there is problem with that, there is nothing to remove on mine at moment, but at least I know to put 1 in is reverse of that. I may run out and take look and see what they did to the wiring or try to anyhow
, I just went and took top covers and this is what I found.
With this, the only way that you could cancel the turn signal would be to center the switch inside (button always stays at the center, but not the switch). Pushing it in would not help.
Erdeniz Umman is online now
post #45 of 60 (permalink) Old 06-29-2017, 05:36 AM
Which coincidentally is the exact problem he has.
post #46 of 60 (permalink) Old 07-11-2017, 08:30 PM Thread Starter
big PIA
MysticFour's Avatar
I have not forgotten about my post, took me a week or so before I ordered the cancel unit. Says from July 14 to July 28th for delivery. Will update after I get the part and install. I know most everybody likes to know the end results
post #47 of 60 (permalink) Old 07-12-2017, 12:35 AM
Is it coming from China?
post #48 of 60 (permalink) Old 07-12-2017, 04:25 AM Thread Starter
big PIA
MysticFour's Avatar
Close, says from Canada
post #49 of 60 (permalink) Old 07-12-2017, 12:12 PM
Year: 94
Model: 1500 SE
its its ebay, the expect date is based on some complex algorithm that involves no less than 3 trips to the space station....
before loading for local delivery to your home by drone
Aloha Tom is offline
post #50 of 60 (permalink) Old 07-15-2017, 09:52 PM Thread Starter
big PIA
MysticFour's Avatar
Got my cancel unit, installed and most everything is working correctly.
It is not cancelling after a turn, does cancel after several second, canceled when I push button in. I am far happier with it now than I was, just want to figure out rest if possible, made sure the pin was centered in the slot and it looked correct
GL1500 turn signals cancel before making a turn ob1jeeper Goldwing Technical Forum 40 08-06-2014 10:10 AM
94 Interstate auto cancel turn signals mtfamily Goldwing Technical Forum 4 08-17-2011 06:44 PM
GL1100 self cancel turn signals box Goldwing Technical Forum 3 04-16-2011 09:37 PM
Manually cancel GL1500 turn signals BHAZLET Goldwing Technical Forum 16 03-13-2011 06:18 PM
GL1800 turn signals auto-cancel gwjr Goldwing Technical Forum 4 04-30-2010 07:50 AM
