GL1500 turn signals won't cancel - Page 6 - Steve Saunders Goldwing Forums
 10Likes
post #51 of 60 (permalink) Old 07-15-2017, 10:43 PM
Did you get the peg in the slot for the cancel units steering angle sensor? When you turn the forks the sensor should move as the forks do. It is not unusual for the steering angle to be too slight. Then it will have to cancel by distance. As you leave a stop sign etc. intentionally turn the forks extra sharp, while moving. The turn lights should cancel pretty quick then. I'm not sure but I think you are good to go. It is not unusual for me to travel a half block or more before they cancel if I don't turn real sharp. Real sharp they cancel pretty fast.
redwing52 is offline
post #52 of 60 (permalink) Old 07-16-2017, 08:02 AM
Pure Texas's Avatar
Make: Goldwing
If it cancelas after several seconds then it is doing its job,it doesn't cancel immediately after it strait end up.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #53 of 60 (permalink) Old 07-16-2017, 10:56 AM Thread Starter
big PIA
MysticFour's Avatar
The peg is in the slot, I tried sharp turn but no difference. As far as I am concerned it is ok, cancels itself in roughly 1/2 block or so
redwing52 likes this.
MysticFour is offline
post #54 of 60 (permalink) Old 07-16-2017, 11:18 AM
Good job!!
post #55 of 60 (permalink) Old 07-16-2017, 03:05 PM
Pure Texas's Avatar
Make: Goldwing
Not sure but it might cancel on mph?
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #56 of 60 (permalink) Old 07-16-2017, 04:13 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
The auto cancel function will be as follows
1.There is no lean angle input, either at low or high speeds.
2.The turn signal duration is defined only by distance, not by time, 500feet (150m), and it is same at low and high speeds.
3. Steering angle sensor is effective even at very low speeds like 5mph. It will cancel the turn signals after completing the turn, without waiting for the distance.
Erdeniz Umman is online now
post #57 of 60 (permalink) Old 07-16-2017, 08:22 PM Thread Starter
big PIA
MysticFour's Avatar
It doesn't cancel following the turn, but I still am happy cause I had no cancel before that other than pushing switch towards other direction
post #58 of 60 (permalink) Old 07-16-2017, 08:29 PM
Pure Texas's Avatar
Make: Goldwing
You should be able to just press the button in to cancel,but didn't you say it canceled AFTER A FEW SECONDS AFTER A TURN.?
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #59 of 60 (permalink) Old 07-16-2017, 08:32 PM Thread Starter
big PIA
MysticFour's Avatar
That is what I do, the only thing not working I believe isn't is the turn part, but I can live with it
post #60 of 60 (permalink) Old 07-16-2017, 08:33 PM Thread Starter
big PIA
MysticFour's Avatar
At about same as if I was going straight
GL1500 turn signals cancel before making a turn ob1jeeper Goldwing Technical Forum 40 08-06-2014 10:10 AM
94 Interstate auto cancel turn signals mtfamily Goldwing Technical Forum 4 08-17-2011 06:44 PM
GL1100 self cancel turn signals box Goldwing Technical Forum 3 04-16-2011 09:37 PM
Manually cancel GL1500 turn signals BHAZLET Goldwing Technical Forum 16 03-13-2011 06:18 PM
GL1800 turn signals auto-cancel gwjr Goldwing Technical Forum 4 04-30-2010 07:50 AM
