1980 gl1100 overheats within 5 minutes - Page 2 - Steve Saunders Goldwing Forums
post #11 of 12 (permalink) Old 07-14-2017, 01:47 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Good point Dennis but the head gasket would address the overheating and all other symptoms. It's good to be sure but I bet it will be a head gasket. Not likely it has three problems when one could be responsible for all 3 symptoms.
Exactly a failing water pump can look like a head gasket has failed and a water pump that is failing can and will blow a head gasket.
If it were me I'd spend the extra hundred bucks and replace that water pump at the same time.
In fact I'd replaced the water pump and see if your problems go away before I change the head gaskets.
Anyway it sounds like you're not going to change the water pump so just remember in a few months from now when you're in the same situation change the water pump while you're replacing the head gaskets again.
JeffMayfield is offline
post #12 of 12 (permalink) Old 07-14-2017, 07:27 PM
Year: 1985
Model: Aspencade
A compression check on the engine would go a long way towards determining if there is a bad head gasket. You can probably even borrow a compression gauge from the local auto parts store.
OldSchool_IsCool likes this.
Wes Scott is offline
1980 GL1100i overheats fast on acceleration Deadweasel Goldwing Technical Forum 31 06-24-2012 06:27 PM
GL1100 Overheats bmoney83 Goldwing Technical Forum 2 07-13-2009 08:48 PM
1200 overheats after radiator work 308guy Goldwing Technical Forum 4 10-03-2008 07:58 PM
GL1100 Overheats William_86 Goldwing Technical Forum 15 08-04-2008 06:18 PM
gl1100 overheats hossners Goldwing Technical Forum 8 05-16-2005 06:48 PM
