Crankshaft/ timing belt gears - Page 2 - Steve Saunders Goldwing Forums
 4Likes
post #11 of 17 (permalink) Old 07-13-2017, 05:34 AM
If the key is still tight in the cam all you need is a new gear wheel & maybe a new key, or it may be only the key worn.
post #12 of 17 (permalink) Old 07-13-2017, 11:13 AM Thread Starter
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
The shaft I am having troubles with is the center shaft. Where the 2 belt gears are located. The rear one is where I have 1/8 inch slop. This is causing the motor to have a knock when running. I believe because the belt is 1/2 tooth off due to the slop.
These are not aluminum as a magnet does attach to the center gears.
So is spot welding feasible?
Is there a key for these two belt gears?
Wilcoy02 is offline
post #13 of 17 (permalink) Old 07-13-2017, 11:29 AM
You HAVE to determine whether the wear is in the pulley or the shaft. No one can give any useful advice without knowing what is worn.
post #14 of 17 (permalink) Old 07-13-2017, 11:39 AM
Year: 1985
Model: Aspencade
The Huntington Beach website does not show keys but the drawing for the crankshaft shows a key slot.
I would assume they have keys since 1200 does.
From the 1200 service manual "If the bolt is properly torqued and one or both of the pulleys is loose, disassemble and inspect the pulley keyways for wear."
Wes Scott is offline
post #15 of 17 (permalink) Old 07-13-2017, 12:04 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Have you synchronized the carburettors?
Erdeniz Umman is offline
post #16 of 17 (permalink) Old 07-13-2017, 04:49 PM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
I would try many options before welding the crankshaft. Pull the belts, radiator and crank pulleys to see what's wearing. Perhaps you should re-title this with crankshaft pulleys rather than camshaft pulleys to not mislead potential advice. My guess is that the pulley has worn its slot some. Replacements are cheap and plentiful. A good mechanic/ machinist could take risks make a wider key and pare it down with a file to fit both snugly.
Welding it could be the last straw.
Ekvh1 is offline
post #17 of 17 (permalink) Old 07-19-2017, 06:42 AM
Year: 2006
Originally Posted by Wes Scott View Post
With the slop you have described you should be able to slide the gear off without any problems after the bolt is removed.
To remove the key from the shaft, a small hammer and a punch should let you GENTLY tap it out of the groove. The moon shaped key should start coming out if you tap staight back on it. I prefer trying to tap at an angle to pop the front edge upward. Also sometimes helpful is to use a small screwdriver once the key starts lifting to get between the key and the shaft.
Be careful not to drive anything too hard and damage the seals around the shaft.
Diagonal cutter pliers are good tools for removing those keys , - just grab it in the end and lift the plier as a pry bar .
Wes Scott likes this.
Timing Belt cmk033 Goldwing Technical Forum 14 06-12-2016 08:38 PM
timing belt Dodge Goldwing Technical Forum 8 01-24-2016 03:57 PM
Timing Belts - Crankshaft Rotation (Clockwise or Anticlcockwise) 1500GL Keith Davidson Goldwing Technical Forum 10 03-10-2011 09:17 AM
Trouble Turning GL1100 Crankshaft to Timing Mark LamarCycle Goldwing Technical Forum 22 12-20-2009 09:58 PM
timing belt? cmorris Goldwing Technical Forum 5 07-01-2006 08:23 AM
