GL1200 front left brake (hand lever) hardly stops - Page 3 - Steve Saunders Goldwing Forums
 6Likes
post #21 of 54 (permalink) Old 07-16-2017, 03:54 PM Thread Starter
Ronlaufer's Avatar
Year: 1985
Make: Honda GoldWing
Model: GL1200 Interstate
Originally Posted by Pure Texas View Post
If you put the bike on the center stand and get the front wheel off the ground and spin the wheel and apply the brake,does it stop the wheel and if it does can you still turn the front wheel while holding the brake lever down,might just be pads bad
No, I can't turn the wheel
Ronlaufer is offline
post #22 of 54 (permalink) Old 07-16-2017, 04:12 PM
Your answer is in the third post.
To get all the air out of the line try turning the bars to the left with the bike on the side stand and pump the lever.
Ken Bergen is offline
post #23 of 54 (permalink) Old 07-16-2017, 05:39 PM Thread Starter
Ronlaufer's Avatar
Year: 1985
OK. I'll try that tomorrow.
post #24 of 54 (permalink) Old 07-16-2017, 08:18 PM
Pure Texas's Avatar
Make: Goldwing
Seems like the system is WORKING as it should,now all you need to do is figure out why it's not efficient.Might it have fork oil on it?
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #25 of 54 (permalink) Old 07-16-2017, 11:17 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
He said at the beginning the brake lever is touching the handlebars when he squeezes it with one finger.
And as was stated this typically occurs when there is air in the system.
My favorite way of bleeding brakes is using a clear hose over the bleeder valve so I can watch the old brake fluid and any air leave as I pump the lever and add new brake fluid as needed. The added advantage of using this method is no air is able to be pulled back in to the bleeder valve except possibly around the threads of the valve.
I'm not sure if it was mentioned in this thread but only one of the front calipers is controlled by the front brake lever.
JeffMayfield is offline
post #26 of 54 (permalink) Old 07-17-2017, 06:04 AM Thread Starter
Ronlaufer's Avatar
Year: 1985
As some of the guys suggested, I put the bars to the left with the bike on the side stand and did the bleeding again. The presume is the same. No change at all.
post #27 of 54 (permalink) Old 07-17-2017, 12:39 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Does that mean you can pull the lever to the grip with one finger?
post #28 of 54 (permalink) Old 07-17-2017, 05:06 PM Thread Starter
Ronlaufer's Avatar
Year: 1985
Yes. It's the same
post #29 of 54 (permalink) Old 07-17-2017, 06:57 PM
Watch the caliper as you pull the lever, does it have any perceptible movement? Put your hand around the hoses and pull the lever, can you feel them grow?
post #30 of 54 (permalink) Old 07-17-2017, 07:07 PM
Did you try just pumping the lever in that position without opening the bleeder?
right hand brake lever RKB53 Goldwing Technical Forum 23 04-10-2016 01:43 PM
GL1200 leaking front brake cylinder by lever new75 Goldwing Technical Forum 7 07-17-2012 10:55 PM
Which front brake disc on GL1500 controlled by hand lever? tnoort Goldwing Technical Forum 11 05-11-2012 02:58 AM
No brake pressure on front left brake lever.. chesterwgunn Goldwing Technical Forum 9 08-28-2008 08:23 AM
Hand lever brake light switch 84wing Goldwing Technical Forum 11 06-16-2007 06:30 AM
