Fork Cap Stripped - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 24 (permalink) Old 07-25-2017, 05:52 AM
RB
RB's Avatar
Send a message via AIM to RB
The bolt isn't stripped just the allen wrench hole..you could drill it out a bit and use an easy out or try one size bigger allen wrench and drive it into the hole until it bites..or as said try a chisel and hammer...to get it started.
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #12 of 24 (permalink) Old 07-25-2017, 11:10 AM Thread Starter
I just want to change my fork oil lol.
Alright I'll give your suggestions a shot.
I'll start with the allen wrench one size bigger and move on from there.
Fingers crossed.
zerodaydave is offline
post #13 of 24 (permalink) Old 07-25-2017, 01:15 PM
Year: 2006
Fingers crossed.
Better find an sligtly larger torx bit , as suggested by Dave .
post #14 of 24 (permalink) Old 07-25-2017, 10:00 PM
Year: 94
Model: 1500 SE
stick an allen or torx in there, tack weld it, unscrew
The important thing here is WHY is the allen stripped- is the cap corrosion bonded, or worse....cross-threaded (I didnt say it- I take it back!)
Aloha Tom is offline
post #15 of 24 (permalink) Old 07-26-2017, 08:15 AM
I still find it rare anyone takes my suggestions.
AZgl1800 and BrianInPA like this.
post #16 of 24 (permalink) Old 07-26-2017, 01:19 PM
Year: 2006
As you , i have also been an professional mechanic for more than 40 year . LOL .
post #17 of 24 (permalink) Old 07-26-2017, 01:38 PM
Grind a notch in the cap. (red) Use a punch (Blue) and drive it right out. It is just cosmetic and you wouldn't even have to replace it if you didn't want to.
redwing52 is online now
post #18 of 24 (permalink) Old 07-26-2017, 02:21 PM
BrianInPA's Avatar
Even a blind nut finds a squirrel every once in a while Dave.
Brian
BrianInPA is offline
post #19 of 24 (permalink) Old 07-26-2017, 05:55 PM
Year: 94
Model: 1500 SE
He will need to replace that cap - the center hole is damaged. Thats how you would tighten the cap normally, correct?
You cannot leave the top hole open, or in a few quick burst it will cover you in fresh fork oil,
The system will pump itself dry with every bump
Ask anyone here with the schrader valve fork caps- failure to install the plug/valve in the cap after filling
WILL result in above mentioned consequence-- as soon as you roll the bike off the centerstand, plop-spray! D'oh!!
Tip: As long as you need a new cap and want to keep up the fork oil changes, there are caps with a removable air valve-
used on certain years and models over the decades
Or you can drill and tap a set of caps and plug them with a small bolt or air valve.
The point is you can remove that valve, leaving a nice opening to refill the forks thru
New fork oil makes the big bike handle better, once a year- when its easy- is worth it.
post #20 of 24 (permalink) Old 07-26-2017, 06:38 PM
BrianInPA's Avatar
I don't think anyone was suggesting using the fork without the cap in place. A torque tip is a slightly different size from the Allen head and may... MAY... remove the cap without having to drill, tap, chisel, or beat it into submission.
Brian
Fork allen bolt stripped, GL1200 JeffMayfield Goldwing Technical Forum 32 01-14-2014 10:07 AM
stripped threads out of fork oil drain hole, doh! Msteele Goldwing Technical Forum 20 04-09-2013 02:46 AM
need cap for fork Hawggy For Sale/Wanted Forum 1 11-08-2012 09:14 AM
Fork cap size PAPete Goldwing Technical Forum 4 05-24-2010 10:47 AM
FORK DRAIN PLUG THREADS STRIPPED POLKWING Goldwing Technical Forum 16 11-05-2006 01:39 PM
