Won't start after working on carbs - Page 2 - Steve Saunders Goldwing Forums
 7Likes
post #11 of 52 (permalink) Old 08-09-2017, 04:25 PM
Model: 1995 GL-1500 SE Trike
Not being a smart ass here but virtually every time you have a running machine that fails after the repair, it has something to do with the repair. Recheck what you did for something that was overlooked. Easily done
donpauli is offline
post #12 of 52 (permalink) Old 08-09-2017, 06:32 PM
The carb rack has to be held almost vertical so the float just barely rests on the needle without compressing the spring.
post #13 of 52 (permalink) Old 08-09-2017, 07:53 PM
What I do is clamp the carb in a vice just tight enough to secure it and not damage it of course.Then I put a piece of hose on the inlet. I blow through the hose and slowly rotate the carb until you just can't blow air through the hose. Carefully measure the float height and adjust. Repeat as necessary until it is just right. Make sure the springs in the needle are springy.
redwing52 is online now
post #14 of 52 (permalink) Old 08-09-2017, 11:39 PM Thread Starter
Year: 1984
Model: GL1200se
No new fuel lines 'not bent'
Retired now and Fired Up to make new friends and see new sights. Ya be look'n for the RV.
Wandering New Trails is offline
post #15 of 52 (permalink) Old 08-09-2017, 11:41 PM
How did you manage that?
And there's no need to yell.
post #16 of 52 (permalink) Old 08-09-2017, 11:49 PM Thread Starter
Year: 1984
Model: GL1200se
RedWing ... I will try what you suggest tomorrow Thanks --- fingers crossed
post #17 of 52 (permalink) Old 08-09-2017, 11:51 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
+1 on what Dennis said. Check for fuel in the float bowls. Unscrew the bowl drains and see what comes out. How is the filter? Check the fuel delivery first. The fuel level in the float bowl needs to cover the jets. They are circled in the picture. When you set the float level, set the carb body on it's side so the weight of the float does not press on the valve spring. Bend the tab to set the level with the tab just touching the spring loaded pin. The float level is not that critical to make it run. It is critical to make it run correctly.
Bike...and Dennis likes this.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is online now
post #18 of 52 (permalink) Old 08-10-2017, 12:04 AM Thread Starter
Year: 1984
Model: GL1200se
Very carefully. And not meaning to yell..
Senior brain moment...
post #19 of 52 (permalink) Old 08-10-2017, 01:19 AM
Can you enlighten us? If you have a technique that works there are plenty here who can benefit.
post #20 of 52 (permalink) Old 08-10-2017, 01:33 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I think Dennis has a very valid point. If you replaced the gas line on the carburetors what did you do about the 90-degree binds that were in the originals.
If you use straight fuel line it tends to crimp once the bike heats up or before stopping the gas.
Perhaps if you could post some pictures of your carburetors that would be helpful and clarify a few things so we can better help you.
JeffMayfield is offline
GL1100 - Hard start, won't start when hot OldSchool_IsCool Goldwing Technical Forum 29 01-01-2018 11:33 AM
86 GL1200A Carbs won't sync, won't idle down! alanc1100 Goldwing Technical Forum 10 09-15-2014 08:47 PM
1982 Honda GL500 Won't start/Bump-Start! NickMe Goldwing Technical Forum 4 08-17-2009 06:42 PM
