Problem with OEM shock rebuild, question about progressives - Page 2 - Steve Saunders Goldwing Forums
post #11 of 19 (permalink) Old 08-29-2017, 04:19 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
instead of using the rubber bumpstops i used poly ones from Summitt Racing
neoracer is offline
post #12 of 19 (permalink) Old 08-29-2017, 10:07 AM
Year: 94
Model: 1500 SE
Matt, the OE front forks are 2 stacked springs. What was inside the Honda rear air shock was my question?
With prog springs in front you wont need any air added unless max load and pulling a trailer-
that air is to offset braking forward weight transfer and stiffen preload.
There is no measure for front drop- it is what it is- barely! When you sit on the bike the main weight is near the rear shocks.
Aloha Tom is offline
post #13 of 19 (permalink) Old 08-29-2017, 10:18 AM
He answered your question in post #10.
post #14 of 19 (permalink) Old 08-29-2017, 06:38 PM Thread Starter
Year: 1985
Model: GL1200 Interstate
The OE rear shock has two springs, not stacked. One is inside the other.
I'm not rebuilding with progressive springs as of now, as great as they may be... maybe next season. I'm just rebuilding the suspension back to OE specs as of now.
matt750 is offline
post #15 of 19 (permalink) Old 08-29-2017, 10:51 PM
Year: 94
Model: 1500 SE
OE front springs are not worth putting back in
Drop the $100 on Prog springs and be rewarded with sportbike like response
My question on internals of OE rear was to learn about 1500 rear air, allegedly has no spring inside vs prog air which can be ridden home with no pressure if a line failed, and still have some suspension action
Dont want to state OE has blah-blah then Dennis gets to harass me because an 84 is different than....
post #16 of 19 (permalink) Old 08-29-2017, 11:01 PM
My question on internals of OE rear was to learn about 1500 rear air, allegedly has no spring inside vs prog air which can be ridden home with no pressure if a line failed, and still have some suspension action.
But this thread is about a GL1200, apples and oranges.
Ken Bergen is online now
post #17 of 19 (permalink) Old 08-29-2017, 11:05 PM
Year: 94
Model: 1500 SE
I am allowed to ask a question, am I not? Can I get an education here too?
post #18 of 19 (permalink) Old 08-29-2017, 11:18 PM
Well you certainly are my friend.
Again yes.
Of course when you mix models everyone walks away confused.
post #19 of 19 (permalink) Old 08-29-2017, 11:23 PM
Year: 94
Model: 1500 SE
Nobody relies on what I say ken, thats just a filthy rumor I started about myself
84 fork rebuild. Is OEM kit all that is needed Quick Cal Goldwing Technical Forum 23 05-01-2015 06:02 PM
1100 OEM Air Shock Length of Travel OldSchool_IsCool Goldwing Technical Forum 3 10-17-2011 10:33 AM
83 GL1100A Rear Shock Rebuild Problem n4fv Goldwing Technical Forum 5 04-12-2010 09:59 AM
OEM Air shock oil Hobie1 Goldwing Technical Forum 4 10-19-2006 08:45 PM
Anyone out there rebuild 1200 OEM radios? hitechluddite Goldwing Technical Forum 4 02-28-2005 08:50 PM
