82 1100I lower left shock bolt. - Steve Saunders Goldwing Forums
 2Likes
  • 1 Post By DaveO430
  • 1 Post By AZgl1800
post #1 of 9 (permalink) Old 09-16-2017, 09:03 PM Thread Starter
Impersonating a mechanic
PAPete's Avatar
Year: 1982 & 1985
Incompetent amateur mechanic needs help:
Don't ask how I did this. The socket wrench and socket are stuck between the bracket on the swingarm and the saddlebag stay. I made the mistake of sliding the socket over the bolt before finding the female threads (by hand) with the bolt. Now the bolt has slid back into the socket -- which is too long. So the bolt is too long to come out of the socket, and I can't push it up against the female threads.
I've tried everything I know except removing the top nut of the shock, and I'm not sure that would help. FYI: The three bolts on the final drive are attached (finger tight) to the shaft. The axle is out, and the tire is resting on two 2X4's.
Anyone have any ideas? Any suggestions would be appreciated. Thanks.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #2 of 9 (permalink) Old 09-16-2017, 09:20 PM
Looks like you need to remove the saddlebag frame, or at least loosen it enough to get the ratchet out.
Bike...and Dennis likes this.
post #3 of 9 (permalink) Old 09-16-2017, 09:21 PM
a good acetylene torch can get it out :rofl;
DaveO430 likes this.
post #4 of 9 (permalink) Old 09-16-2017, 10:57 PM
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
Yupp..... it's not that tough. You don't have to remove the saddlebag bracket totally but just loosen it enough to wiggle off the ratchet. You'll want to start with the rear bracket that goes around the wheel. 2 bolts on each side and a tap or two with a rubber mallet to loosen it.... out it comes. The rest just need to be loosened.
Ray
88 GL1500
rayworx is offline
post #5 of 9 (permalink) Old 09-17-2017, 09:09 AM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
At one point I was ready to try this -- starting at the front of the bike and working rearward.....
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #6 of 9 (permalink) Old 09-17-2017, 09:14 AM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
Dave and Ray:
Thanks. I'll see if I can get it loose enough to work the wrench and socket out. I was worried about removing the saddlebag bracket without opening a whole new can of worms. Thanks again for the advice.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #7 of 9 (permalink) Old 09-18-2017, 09:06 AM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
Thanks, guys.
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
post #8 of 9 (permalink) Old 09-18-2017, 09:51 AM
Large Member
wilmo's Avatar
Typically, I found it easiest to remove the rear wheel with the left saddlebag frame removed anyway. It's just a few extra bolts and makes wheel removal really easy.
Wilmo
Rubber side down!
101421 miles as of 091418
wilmo is offline
post #9 of 9 (permalink) Old 09-18-2017, 10:58 AM Thread Starter
PAPete's Avatar
Year: 1982 & 1985
Yeah, I can understand that, now that I've done it once. Don't know why I was so paranoid about it....
Pete
82 GL1100-I -- PA
85 GL1200-A -- ID
PAPete is offline
97' 1500 SE left rear, bottom shock bolt, need help. Hodgy Goldwing Technical Forum 16 08-12-2014 07:47 AM
Difficulty with GL1500 Left shock caliper bolt removal Cyclonenw Goldwing Technical Forum 15 01-05-2013 10:24 PM
82 1100i fork and rear shock seals nphoenix Goldwing Technical Forum 4 06-08-2011 08:21 AM
GL1500 left lower shock bolt won't go back in DickKelso Goldwing Technical Forum 6 05-04-2011 11:26 AM
Right side lower shock bolt GerryAllan Goldwing Technical Forum 2 07-10-2009 10:45 PM
