DHS Shifter Lever Upgrade - Page 2 - Steve Saunders Goldwing Forums
post #11 of 15 (permalink) Old 09-26-2017, 11:13 AM
Originally Posted by garyem View Post
The 1/4 bolts work in the shifter arms right Do they fit in them jionts from amazon
Yes, I got bolts with a long enough unthreaded shank to go almost all the way through then cut off the excess.
post #12 of 15 (permalink) Old 09-27-2017, 10:51 AM Thread Starter
Make: honda
Model: gl1800
So I would be looking at the cut off just inside the heim joint just about flush and the threads out the other end I know dumb question
garyem is offline
post #13 of 15 (permalink) Old 09-27-2017, 02:15 PM
I hope you understand me better than I understand you. The bolt is going to go through the heim joint, through the spacer, through the shift arm and into the nut. The threads need to be far enough inside the shift arm that the nut has a little more than enough thread to tighten down on but the smooth part of the bolt goes through most of the parts.
post #14 of 15 (permalink) Old 09-27-2017, 03:37 PM Thread Starter
Make: honda
Model: gl1800
I do under stand ya
I took the left cowl off and looked at the shifter it makes sense now
garyem is offline
post #15 of 15 (permalink) Old 09-30-2017, 04:15 PM
Another tip, or 2, the DHS guy says grind the button off the end of the old pin to drive it out. I disagree, cut it off on the side with the heim joint and drive it out the other way. Set the button over a socket it will fit in and use a punch & hammer. Also before you take the shifter off measure to somewhere fixed so you can adjust it to the same height, or a little higher or lower if you prefer.
Need to replace GL1000 shifter lever. starfleethero Goldwing Technical Forum 6 09-24-2013 06:53 AM
GL1500 Shifter Lever . SOLVED !!!! 96aspencade For Sale/Wanted Forum 4 07-03-2013 10:38 AM
GL1500 shifter shaft wobble/play after removing heel-toe shifter VDIGUY Goldwing Technical Forum 4 03-10-2013 09:11 PM
WTB Shifter, pegs, Brake lever setup, and Kuryakan Hy pegs Chromo For Sale/Wanted Forum 8 04-16-2012 12:20 AM
two clear drain hoses with plugs near shifter lever? pvwheeler Goldwing Technical Forum 8 06-03-2011 07:03 AM
