83 Engine Wires - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 10-15-2017, 05:13 PM Thread Starter
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
83 Engine Wires
I am replacing an 83 engine.
The old engine has 3 different sets of wire coming out of it.
1 set) Green with brown wire & Blue with brown wire. {comes out of the front of the engine above the oil filter} Honda plug on it.
2 set) 3 yellow wires. Honda plug to stator.
3 set) Blue wire, 2 white wires, and a yellow wire with a Honda plug.
The new 83 engine has:
1set ) Red, White, Black, Blue, Green, and Yellow wire with a Honda plug.
2set) 3 yellow wires with Honda plug. Stator
I do not know how to connect set 1 wire.
I have not found the bike plug for set 3.-- I know it is there as I unplugged the wires from the old engine.
Any advice would be appreciated.
_________________________________
Wilcoy02 is offline
post #2 of 5 (permalink) Old 10-15-2017, 05:22 PM
I would think that the first engine is an Interstate so the front plug only had neutral and over drive indicators.
The second engine is likely an Aspencade with indicators for all five gears plus neutral.
Ken Bergen is online now
post #3 of 5 (permalink) Old 10-15-2017, 05:25 PM Thread Starter
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Old engine was an Interstate. Not sure of the new engine. You are probably correct.
Any suggestions how I might connect the 1st set of wires. Which wires will I not need?
Any idea of where the set 3 wires might be on the bike?
Wilcoy02 is offline
post #4 of 5 (permalink) Old 10-15-2017, 07:43 PM
Use the blue and the green from the shift switch, match to the blue/brown & green/brown.
The other connector should be next to the stator connector, to the left of the battery.
post #5 of 5 (permalink) Old 10-15-2017, 10:46 PM Thread Starter
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Thank You.
I will cut the plug from the old engine and solder it to the Green and Blue wires in the morn.
The other 4 wires I will tape, and forget them.
Wilcoy02 is offline
How to protect wires from engine heat William_86 Goldwing Technical Forum 5 05-04-2016 12:30 PM
Starter Relay Regulator heats up wires and bogs down engine Read more: http://goldwi JRLewis Goldwing Technical Forum 5 10-01-2014 04:36 PM
GL1100 engine swap, wires question ARMS Goldwing Technical Forum 3 09-16-2012 04:31 PM
1991 GL1500 Aspencade engine swap with a 97 engine. Mr Magic Fingers Goldwing Technical Forum 33 05-04-2012 01:31 PM
Engine swap 85 gl1200 asp getting interstate engine Question christoph Goldwing Technical Forum 7 08-24-2008 10:37 PM
