Amplified Antenna - Page 2 - Steve Saunders Goldwing Forums
post #11 of 20 (permalink) Old 10-22-2017, 10:57 AM
Large Member
wilmo's Avatar
I have one of those now. I also had one on my 86. It works every bit as well as the ugly long antennaes. I have not noticed any drop in reception. I have mine sitting on the bar under the seat and wired into the ACC on the fuse block. Well worth the lousy $4 I spent on it. Won't work the CB, however, but I don't care about that anyway, I don't use it.
Wilmo
Rubber side down!
101421 miles as of 091418
wilmo is offline
post #12 of 20 (permalink) Old 10-22-2017, 12:32 PM Thread Starter
wedoo2's Avatar
Model: 1982 GL1100 Interstate
This could work
Jack
wedoo2 is offline
post #13 of 20 (permalink) Old 10-22-2017, 01:16 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
WeDoo2,
Unfortunately there is no good solution to an antenna on a motorcycle. As previously stated a motorcycle lacks a ground plane. A signal amplifier will amplify the entire signal, the good and the bad. If you are having reception problems with the antenna you have, then all an amplifier will do is make the good and bad signal stronger to the radio.
There are two things that can improve your reception. Get the antenna higher and simulate a ground plane. Also, the antenna needs to have a tuned length to the radio frequency you are trying to receive. Antennas that are base loaded will simulate the ground plane. Antenna designed for boats and motorcycles are called base loaded. This will help the ground plane problem.
The short quarter wave antennas will only work when you are close to the transmitter. If you are in a rural area and trying to get a distant station you will need a tall full wave (long and tall) antenna.
The ebay antenna you show looks good to me. It is tall and the coil will give it the base loading you need. It appears to be very much like the antenna that came on my GL1200. I recently installed a new stereo on my bike, I was surprised how well the stock antenna worked, but I do live in the city. You can look at marine am/fm antennas. However, they may not have the needed height.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #14 of 20 (permalink) Old 10-24-2017, 07:50 AM Thread Starter
wedoo2's Avatar
I've seen several bikes with two antennas. Wonder how that works, a splitter somewhere?
Jack
wedoo2 is offline
post #15 of 20 (permalink) Old 10-24-2017, 07:52 AM
DenverWinger's Avatar
One for AM/FM, the other for CB radio....
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #16 of 20 (permalink) Old 10-24-2017, 08:40 AM Thread Starter
wedoo2's Avatar
Makes sense
Jack
wedoo2 is offline
post #17 of 20 (permalink) Old 10-25-2017, 01:35 PM
briese's Avatar
Originally Posted by wedoo2 View Post
After looking around I found that I do not have the cable that came with my OEM antenna. I have the bracket and the antenna. I did an ebay search and found this antenna. In the description it says: It comes with a MOTOROLA-type, cable end, push fitting for the above systems only. (Clarion system)
https://www.ebay.com/itm/Antenna-CO-...5ZF41J&vxp=mtr
I thought that I heard that the OEM cable would not fit the standard radio connections of today's radios. I have found a couple of the 1/4 wave antennas that are the longer wire type but then I will have to fit the correct cable to them. This is not as easy as I figured.
I appreciate the responses so far, although some are over my head. I'm going to stop by Audio + this week to see if they sell something I can fit on the bike.
This antenna should work just fine for your application.
1998 - GL1500 w/175,000 miles
2003 - GL1800 w/106,000 miles
briese is offline
post #18 of 20 (permalink) Old 10-26-2017, 08:31 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
most 1200 applications that are using two antennas,the left one is a "dummy" and is not connected ,in inorder to use it you have to disconnect the antenna splitter underneath the cb radio and run an extension cable out to the antenna(left)
neoracer is offline
post #19 of 20 (permalink) Old 10-26-2017, 11:26 AM
briese's Avatar
Does that hold true for the 1100 as well because that is what the original poster is asking about?
briese is offline
post #20 of 20 (permalink) Old 10-27-2017, 04:11 PM Thread Starter
wedoo2's Avatar
I don't (didn't) have an antenna splitter on my 1100.
Jack
wedoo2 is offline
Is a cb antenna and a radio antenna the same. Quick Cal Goldwing Technical Forum 22 06-06-2015 10:46 AM
Amplified Noise in Headset, GL1800 baldguy Goldwing Technical Forum 2 05-25-2013 08:40 AM
GL 1100 ~ How big is the antenna hole on the Antenna Mount? bark Goldwing Technical Forum 15 05-12-2011 10:22 AM
Amplified road noise using Zumo 550 rhjiii46 Goldwing Technical Forum 1 12-03-2007 08:50 AM
is a cb antenna differant than a fm antenna JBz Goldwing Technical Forum 6 10-05-2006 04:13 PM
