Lowering my wing - Steve Saunders Goldwing Forums
 10Likes
post #1 of 23 (permalink) Old 10-22-2017, 09:43 AM Thread Starter
Shorty Thompson's Avatar
Year: 1986 ,1984 , 1982 , 1985 , 1983 .
Make: Honda , honda , honda , honda , Suzuki
Model: Interstate , Aspencade , Interstate
Lowering my wing
This has probably been asked before , but I can't help myself.
Has anyone , or Does anyone know if my '86 Aspencade can be lowered ? I'm 5'4" with a 29"-30" inseam. While driving is alright, stopping and stand still is on tip toes. Suggestions will be taken into consideration.
Thanks !
Shorty Thompson is offline
post #2 of 23 (permalink) Old 10-22-2017, 10:31 AM
Rednaxs60's Avatar
Difficult at best to lower a 1200. Would recommend your first course of action to be removing almost all of the seat material and just before you get to the seat pan, have a good gel pad installed. You should be able to get at least 2 inches this way. Check in your area for a shop that does custom seat fittings.
My son-in-law is short in the legs as well and had this done to his 2014 Moto Guzzi California touring bike. He is sitting almost on the seat pan with a good gel pad installed. This will be a lot easier and less expensive in the long run. Hope this helps.
Cheers.
Shorty Thompson likes this.
Ernest
Rednaxs60 is offline
post #3 of 23 (permalink) Old 10-22-2017, 10:33 AM
Magic Moderator
trike lady's Avatar
Also try a pair of 'Logger' boots with the thick sole.
Retired trike builder.
trike lady is offline
post #4 of 23 (permalink) Old 10-23-2017, 07:37 PM Thread Starter
Just incase . Any other suggestions ?
post #5 of 23 (permalink) Old 09-03-2019, 04:52 AM Thread Starter
I know this is an old thread , but I had to come looking for it. I got another seat to cut down. I talked to an upholsterer and she quickly said no she couldn't do it. I don't think she was listening to what I was saying or wanted. However ,,,,, she did have a couple contacts that might do the seat for me. Wish me luck !!!!!!!
post #6 of 23 (permalink) Old 09-03-2019, 05:37 AM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
Cutting the seat down will definitely help get your feet on the ground. One other possibility is shorter rear shocks.
Hopefully the seat work does it for you .
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #7 of 23 (permalink) Old 09-03-2019, 09:03 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
Cutting the seats height down helps a little, but taking some of the sides out so the width is narrower helps the most. Currently you’re probably having to slide to one side to allow the leg to fall straight down. For most people you lose a fair amount of your inseam due to the width of the seat and your own personal hip width.
Ekvh1 is offline
post #8 of 23 (permalink) Old 09-03-2019, 10:14 AM
Year: 1995
Model: Anniversary Model, triked out by TriKing
In addition, if you simply remove height of the foam, you might compress the remaining foam down to the pan, and have an uncomfortable ride.
A trick is to divide the foam into thirds with a sharpie pen.
Remove the upper two thirds. Then, replace the center third with a higher density foam to compensate.
Shape to suit.
JohnUSA is offline
post #9 of 23 (permalink) Old 09-03-2019, 10:18 AM
joe in calif's Avatar
Check google for someone or someplace that specializes in motorcycle seat. It will cost a little more but you will have a good looking seat as well as a comfortable one. Saddleman, Corbin,
Russell day long, https://www.billmayer-saddles.com/
A NEW START ON 1/20/2017
joe in calif is offline
post #10 of 23 (permalink) Old 09-03-2019, 04:34 PM
Bellboy40's Avatar
Year: 2000 & 1994
I had a seat modified with these folks. I was well pleased with the result. You have to schedule shipping the seat to them and then when they get it they have a pretty quick turn around.
http://www.meancitycycles.com/
Larry
-- Albert Einstein
Bellboy40 is online now
lowering Flybynight Goldwing Technical Forum 20 02-08-2012 09:52 PM
lowering a gl1100 booya General Motorcycle Discussion Forum 11 09-05-2010 06:44 AM
lowering Dusty Goldwing Technical Forum 4 07-20-2009 08:48 PM
lowering the 1800 gold wing is there a way??????????? honda03 Goldwing Technical Forum 13 04-09-2009 08:36 PM
lowering blocks newtscoots Goldwing Technical Forum 1 12-13-2006 08:52 PM
