How much dashpot fluid is needed? - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 24 (permalink) Old 12-18-2017, 06:04 PM Thread Starter
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Ken
You are probably correct in that the tach does not use fluid.
Rayjoe
I hate it when I am reading some one else's post and they do not state what they are working on. I am very guilty of not stating what I am working on.
It is an 83 gl1100.
I have the tach apart. I see the can/pot on the needle shaft.
Now I will try to figure out how to refill it.
I have had 3 tachs on this bike so I tried to research and get one to actually work. I have replaced the cable.
I assumed that the tachs had fluid in them as they say not to store them face down.
When Honda sold them in the box. The box stated to keep this side up.
Wilcoy02 is offline
post #12 of 24 (permalink) Old 12-18-2017, 06:13 PM
Originally Posted by rayjoe View Post
The gauges that I've seen use fluid in a "can/pot" that is attached to the needle shaft. I not sure if you can get fluid into it thru the cable hole. Anything is worth a try.
Rayjoe
Not trying to get any fluid into the tach, just cleaning and lubing the mechanism where the cable connects to it.
post #13 of 24 (permalink) Old 12-18-2017, 06:51 PM
rayjoe's Avatar
Originally Posted by Wilcoy02 View Post
Ken
How about a picture of the tach with the "can" showing?
Can you move the needle with your finger?
Going to an X-mas party now. Check in with you later.
Rayjoe
rayjoe is offline
post #14 of 24 (permalink) Old 12-18-2017, 07:46 PM Thread Starter
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Here is the tube that needs filling.
I have no clue yet how to fill it. I do not want to mess with the spring htat is in there.
It is the center of the cluster. The little capsule above the dome .
click on pic and you can see it a lot better.
Wilcoy02 is offline
post #15 of 24 (permalink) Old 12-18-2017, 07:52 PM
I think you are mistaken. That looks like the standard mechanically driven Honda tach. The spring is set to govern the unit.
If you are getting a bounce in the needle, my bet is a dry drive.
limpy45 likes this.
post #16 of 24 (permalink) Old 12-18-2017, 08:19 PM Thread Starter
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Thanks Dennis.
I am trying to learn what makes this thing tick.
Why did Honda put this side up on the tach when they were in boxes?
I had always thought because there was a fluid in it somewhere.
Wilcoy02 is offline
post #17 of 24 (permalink) Old 12-18-2017, 09:14 PM
Pure Texas's Avatar
Make: Goldwing
Had one apart and it was driven by the cable and what I would call a magnatic spinner inside a cover that looked like the round thingie.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #18 of 24 (permalink) Old 12-18-2017, 09:32 PM
I have taken apart many speedometers from old cars just to see what made them tick. There is a spinning magnet inside that can that is spun by the cable. The clearance is very critical so everything works correctly, probably why they are boxed 'this side up'.
limpy45 is offline
post #19 of 24 (permalink) Old 12-18-2017, 10:11 PM
Make sure the cable is routed correctly, any too sharp bends and the tach will bounce.
rayjoe likes this.
post #20 of 24 (permalink) Old 12-18-2017, 10:22 PM
rayjoe's Avatar
fluid
Back from the party!! Nice evening.
So, back to your tach. I tend to agreed with bike and Dennis. Looks like a standard setup.
What is the tach doing, or in this case, not doing?
Have you checked that the drive is working?
Did you replace the whole cable, or just the inner?
Later,
Rayjoe
rayjoe is offline
how much fluid? wingbiker06 Goldwing Technical Forum 5 04-12-2011 09:15 AM
Where is the fluid going? Snorebaby Goldwing Technical Forum 19 01-03-2010 05:37 PM
fluid changes n2xwv Goldwing Technical Forum 4 07-14-2006 06:25 AM
Clutch Fluid/Brake Fluid/Coolant! 1986gw Goldwing Technical Forum 20 06-05-2006 12:44 AM
Fairing plastic needed, dam brake fluid problem :o( Wildcat For Sale/Wanted Forum 0 05-31-2006 11:57 AM
