How much dashpot fluid is needed? - Steve Saunders Goldwing Forums
 5Likes
post #1 of 24 (permalink) Old 12-18-2017, 12:47 PM Thread Starter
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Does any one know how much dashpot fluid (50,000CST silicone fluid) is required in the tachometer?
And How does one put the fluid in the tach? Where does it go?
I have the tach apart.
Wilcoy02 is offline
post #2 of 24 (permalink) Old 12-18-2017, 01:14 PM
Model: 2005 1800 with Lehman Trike
Drill a half-inch hole in the metal part, and pour in a quart of 10w40 regular oil, or 1 pint of 0w10 synthetic.
Good luck.
suvcw04 is offline
post #3 of 24 (permalink) Old 12-18-2017, 01:14 PM
Wut??!
post #4 of 24 (permalink) Old 12-18-2017, 02:58 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
May as well check the air pressure in your speedometer while you are in there. Nitrogen fill if it's low.
suvcw04 likes this.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is online now
post #5 of 24 (permalink) Old 12-18-2017, 04:17 PM
rayjoe's Avatar
dashpot fluid
Dashpot fluid is used in some older carbs. Not in the carb per se, but in a little can or pot attached to the throttle plate shaft. I believe it was used to prevent throttle plate flutter. And he might be referring to fluid used to dampen the tach needle. Older tach and speedos used fluid as a means to prevent the needles from bouncing.
That's my story and I'm sticking (pun intended) to it!
Rayjoe
rayjoe is offline
post #6 of 24 (permalink) Old 12-18-2017, 05:29 PM Thread Starter
Wilcoy02's Avatar
Year: 1983
Model: GL1100
rayjoe
That is exactly what I am looking for. I do not know how much to put in the tach.
Wilcoy02 is offline
post #7 of 24 (permalink) Old 12-18-2017, 05:33 PM
Originally Posted by Wilcoy02 View Post
rayjoe
Are you sure that the tachometer uses damping fluid as it should read real time?
Bike...and Dennis likes this.
Ken Bergen is online now
post #8 of 24 (permalink) Old 12-18-2017, 05:42 PM
Put some penetrating oil, or even WD-40 in the cable hole and spin it a few dozen times, then some decent quality grease. Replace the cable. If that doesn't fix the problem, start looking for another gauge.
post #9 of 24 (permalink) Old 12-18-2017, 05:52 PM
rayjoe's Avatar
fluid
rayjoe
I can't help you there. The only reason I knew what you were talking about is old age. I had a couple of English sports cars and a few Triumph motorcycles in my youth. I'm no expert, but I remember those old gauges.
I would be surprised if the newer gauges use fluid. Most of the newer ones I've seen have what looks to be a clock spring. You might google Smiths gauges repair or something like that.
In the long run it might be easier to just replace the tach guts.
Rayjoe
rayjoe is offline
post #10 of 24 (permalink) Old 12-18-2017, 05:58 PM
rayjoe's Avatar
The gauges that I've seen use fluid in a "can/pot" that is attached to the needle shaft. I not sure if you can get fluid into it thru the cable hole. Anything is worth a try.
Rayjoe
rayjoe is offline
how much fluid? wingbiker06 Goldwing Technical Forum 5 04-12-2011 09:15 AM
Where is the fluid going? Snorebaby Goldwing Technical Forum 19 01-03-2010 05:37 PM
fluid changes n2xwv Goldwing Technical Forum 4 07-14-2006 06:25 AM
Clutch Fluid/Brake Fluid/Coolant! 1986gw Goldwing Technical Forum 20 06-05-2006 12:44 AM
Fairing plastic needed, dam brake fluid problem :o( Wildcat For Sale/Wanted Forum 0 05-31-2006 11:57 AM
