It overheated. should I be alright? - Page 12 - Steve Saunders Goldwing Forums
 30Likes
post #111 of 206 (permalink) Old 01-21-2018, 06:01 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
i put everything back together and pressed the start button. the motor sounds great! the only problem is the left coolant joint pipe is leaking really bad. i thought i bolted it down at a bad angle so i re-positioned it and pressed down on it as i bolted it down and still no luck. i believe what happened is that gasket sealer stuff i put on did not seal right because the bolts were not bolted in on all the way as it was drying(again, i was too scared of snapping a bolt off). I think i definitely have to take the coolant joint pipe off to clean it well and put it back on. I just fear doing this because the last time i did this it wouldnt go back on as the new o-ring was too firm and didnt let me "squish" it, so i couldnt even line up the bolt holes on the pipe with the ones on the head. beacuse of that, I had to take the head off, bolt it to the head and then bolt the head to the engine block. it was terrible beacuse i had to take eveything apart again and redo the belts( such a pain!!) maybe i should just keep the same o-ring and since it is already in the "shape" it needs to be in? suggestions?
crimsonwing is offline
post #112 of 206 (permalink) Old 01-21-2018, 06:41 PM
Didn't the book explain that procedure?
post #113 of 206 (permalink) Old 01-21-2018, 08:35 PM
Is the leak coming from the o-rings or between the housing and cylinder head? Are you installing the o-ring in the thermostat housing and coolant tube housing then slipping the pipe in to the already installed o-rings? Grease on the o-rings it should go right together. It almost sounds like you put the o-ring on the tube then tried to push the tube with o-ring installed in to the housings. That is not correct. See what is attached.
redwing52 is online now
post #114 of 206 (permalink) Old 01-21-2018, 10:56 PM
I think i definitely have to take the coolant joint pipe off to clean it well and put it back on. I just fear doing this because the last time i did this it wouldn't go back on as the new o-ring was too firm and didnt let me "squish" it, suggestions?
JamesPal has the fix for you.
He use xylene and Wintergreen mixture to soften up the rubber parts when he rebuilt the carbs on his bike.
he just posted up a video today on how to do that.
post #115 of 206 (permalink) Old 01-22-2018, 02:36 AM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
maybe im just looking in the wrong chapter?
redwing, its leaking between the housing and head. o rings are fine. the problem is if i take the housing off, it wont go back on because the new o-ring is too firm ad wont let me push the housing back on all the way. ill try and just keep the same o-ring on there and see how it works out?. AZ, ill try the rubber renewal product if it comes down to it.
post #116 of 206 (permalink) Old 01-22-2018, 02:48 AM
You're putting the oring in the groove in the housing not on the tube, correct?
Ken Bergen is online now
post #117 of 206 (permalink) Old 01-22-2018, 12:12 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
correct. i just reeaaaally don't want to take the head off. not only because all the labor, but i dont want to reuse the gasket.
post #118 of 206 (permalink) Old 01-22-2018, 01:07 PM
Pure Texas's Avatar
Make: Goldwing
It should not be that tight,some pressure but not as much as you indicate,is the o ring Honda. The elbo isnt cracked is it ?try loosening the other side for some slack.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #119 of 206 (permalink) Old 01-22-2018, 01:23 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
o ring is honda, and elbow is not cracked. by the other side do you mean the other housing on the other head?
edit: please remember all this is what happened LAST time I did the head gaskets. i've done nothing to the housing as of now, it still sits on the head connected to the pipe. How do I get it off the pipe without accidentally pulling the pipe off? or does the pipe have to be screwed off? ill look in the book again to seek info, any tips or tricks would be appreciated!
post #120 of 206 (permalink) Old 01-22-2018, 02:26 PM
I would think there would be no issue as Ken said. Is it possible you have an old o-ring still in there somewhere. That is 2 o-rings rather than 1 on each end. Usually you can turn the pipes with your fingers when it is all bolted back together. I might ask if you have the right pipe on the left side but I don't think that is possible. The right pipe is way too long to get it on the left side. Something weird. If you would loosen the thermostat housing that might help but that might not be good to upset that gasket. Loosening the other side would be no help of course.
Overheated 1200a Dwight58 Goldwing Technical Forum 24 06-12-2014 11:31 PM
Alright! Found my new motorcycle... AZgl1800 Miscellaneous Forum 4 06-21-2008 01:28 PM
Alright ........Sudden trip ccsailor Miscellaneous Forum 12 01-22-2008 08:46 AM
Overheated GL1000 RD_Wingman Goldwing Technical Forum 9 04-03-2006 12:05 AM
