Dragging Brake Update - Page 5 - Steve Saunders Goldwing Forums
 5Likes
post #41 of 45 (permalink) Old 01-06-2018, 11:32 AM Thread Starter
captng1's Avatar
Model: 1984 GL 1200 Standard
Originally Posted by Dodge View Post
Glad it's easy for you ! Usually the threads on the master are messed up and are hard to start. That internal pressure thingy isn't reachable. If you haven't rebuilt the master it would be a good place to start. Be sure to get you boot cover in right and your split ring in correctly. If you don't the entire internals will move and not function correctly. Just a thought.
Thanks Dodge!
captng1 is offline
post #42 of 45 (permalink) Old 01-06-2018, 02:46 PM
Carshandco's Avatar
Model: 1979 GL1000
rear, or front master cyl?
If both front & rear calipers are sticking, wouldn't it be the front master cylinder acting up?
If so, there are brand new, cheap chinese knock offs available for the 1200 (see seller partsangel on EBay)...no help if it's the rear master cyl though..nothing new available..
I replaced my front m cyl on my GL1000 with one of these, works great!
good luck,
Carsh
Carshandco is offline
post #43 of 45 (permalink) Old 01-06-2018, 03:14 PM
Carsh
From the '83 forward 'Wings have had linked braking. On the 12s the right front caliper is actuated by the rear master.
post #44 of 45 (permalink) Old 01-06-2018, 03:38 PM
Carshandco's Avatar
Model: 1979 GL1000
yeah, I get it now, after looking at the fische, would have to be the rear m cyl acting up,
good luck finding a new one, rebuild the old using lots of compressed air thru the 2 relief ports..
post #45 of 45 (permalink) Old 01-06-2018, 04:30 PM
Carshandco's Avatar
Model: 1979 GL1000
I see now, apparently the F Mcyl only operates the L F Caliper, not tied in to the rear system at all..
Rear Brake Dragging captng1 Goldwing Technical Forum 15 12-28-2016 10:02 AM
Rear Brake Dragging captng1 Goldwing Technical Forum 14 03-13-2016 12:38 PM
Videos. Have a locked or dragging brake. How to remove a stuck brake caliper piston Quick Cal Goldwing Technical Forum 2 05-04-2015 11:37 PM
rear brake dragging razorbackwingman Goldwing Technical Forum 15 07-26-2008 08:25 PM
Dragging Rear Brake paramedic Goldwing Technical Forum 9 12-04-2005 02:24 PM
