New tire for my GL 1500 pic's of hub and question - Page 3 - Steve Saunders Goldwing Forums
 7Likes
post #21 of 26 (permalink) Old 04-16-2019, 04:01 PM
BEN2112's Avatar
Year: 1995
Model: 1500i
M-77
Those are CLEAN splines with the new M-77 on them. I just took it back off and found the 2 weep holes on the shaft. Do you thing I can just shoot some w-d 40 in them?
SHINY SIDE UP
BEN2112 is offline
post #22 of 26 (permalink) Old 04-16-2019, 04:11 PM
BEN2112's Avatar
Year: 1995
Model: 1500i
M-77
that was a stupid question for me to ask. I'm using the hypoid gear oil too clean the ports...duuuuuuu. ooops BRAIN FART
SHINY SIDE UP
BEN2112 is offline
post #23 of 26 (permalink) Old 04-17-2019, 08:21 AM
BEN2112's Avatar
Year: 1995
Model: 1500i
Final drive back on
help!!!! I can't get my final drive back on to u-joint. anyone have any tricks? I heard a comment on bumping the starter. My finger is bleeding from trying to move the spline to see if I'm in. I had it on yesterday but took it off again to check those weep hole weren't covered with m-77.. I'm thinking a stick of dynamite..lol
SHINY SIDE UP
BEN2112 is offline
post #24 of 26 (permalink) Old 04-17-2019, 01:16 PM
Ben,
It is not unusual for the u-joint to come off the transmission output shaft on the engine. If you use a cat off broom stick you can slide it in to the u-joint from the rear. Cut the broom stick plenty long so you have a long enough handle that you can feel around and slide the joint back on the shaft. Once it is on you will be able to get the final in easier if you usee either the finger or bump the engine method.
redwing52 is online now
post #25 of 26 (permalink) Old 04-17-2019, 02:51 PM
BEN2112's Avatar
Year: 1995
Model: 1500i
Hmmmmm. I didn't even consider the u-joint being dislodged. Gotta do some pokin around on that one. Thanks Mike... To Be Continued....
SHINY SIDE UP
BEN2112 is offline
post #26 of 26 (permalink) Old 04-17-2019, 06:38 PM
You shove a cat up there with a broomstick and I'm calling the SPCA!
Jerry Burns and RambozoClown like this.
Speedometer Hub Question HeyJack Goldwing Technical Forum 7 01-12-2015 10:14 PM
Bushtec Tire/Wheel and hub cover. 4cRanch For Sale/Wanted Forum 0 05-01-2011 01:52 AM
Rear Hub Question woody798 Goldwing Technical Forum 12 06-26-2008 10:43 AM
Bearing spun in hub of 88 GL1500 rear tire, now what? bugzapper1 Goldwing Technical Forum 2 06-25-2008 08:09 PM
